Old 03-29-2015, 09:19 AM   #11
WFD
If it`s that well hidden then it`s a PITA, do yourself a favor and while you are there, just remove the whole thing and go with an outside filter instead!
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
Old 03-29-2015, 10:22 AM   #12
I have an 8282 ws and it is located under the kitchen sink behind two panels
Rockwood 8282 WS
2012 F-250 6.2
farfetched is offline   Reply With Quote
Old 03-29-2015, 05:17 PM   #13
I have a 2015 rockwood signature 8289WS. I installed our filter. It was in the lowest panel beneath the drawers under our microwave. I used a Philip screw driver to remove outside screws. I turned water pump and outside water line off. Then I used the white plastic tool which came with my unit to unscrew the filter casing. I hope this helps. Ian Fleischer
IanFleischer is offline   Reply With Quote
cat, water, water filter
