Old 03-28-2015, 03:29 PM   #1
Where is the water filter located?
I just purchased a 2105 Rockwood ultra lite 8286ws. I know it's supposed to come with a water filter. There was even a filter in the kitchen draw when it was delivered. I searched everywhere but can't find the filter housing anywhere. Anyone have any ideas?
njcamper is offline   Reply With Quote
Old 03-28-2015, 03:33 PM   #2
Ford Idaho's Avatar
Spot your water heater from outside, then look inside for a removable panel where the backside of the water heater is.
Look in there.
If it is please consider removing it all together and put it outside.
Old 03-28-2015, 03:42 PM   #3
Look in the garage on the street side, there is probably a short panel held on with 4 screws, remove the panel and you will probably find the water pump and the filter.
Old 03-28-2015, 03:43 PM   #4
Ok great. Thanks. I will check for that.
Old 03-28-2015, 04:53 PM   #5
fonzie's Avatar
Sometimes it is underneath entertainment/TV center behind a door that has multiple hinges and one set needs to be removed, that is where mine is. Subwoofer could be there also.
Fonzie
Old 03-28-2015, 05:12 PM   #6
Ohh. You know that's where I thought it would be because of the city water connection. there is a speaker in there. But I cant get that darn cover off. It has one hinge on the outside and looks like another on the inside. How does it come off ?
Old 03-28-2015, 05:18 PM   #7
fonzie's Avatar
I removed the hinges on the outside of door.....or can you get at it from the pass thru storage as OldCoot mentioned?
Fonzie
Old 03-28-2015, 05:46 PM   #8
Awesome. I new to this forum stuff. But it's great. Thanks for all your help.
Old 03-28-2015, 05:48 PM   #9
fonzie's Avatar
Did you find it? and if yes, from where?
Fonzie
Old 03-29-2015, 05:17 AM   #10
No I didn't take a look yet. I will tomorrow after work. It's supposed to be a bit warmer tomorrow. I'll let you know what I find. Thanks.
cat, water, water filter
