Old 07-24-2019, 05:04 PM   #1
Where's the water filter?
Hello,
I just acquired a 2011 FR 8413BSS. There's a wrench in the owner's packet to remove the water filter housing but I can't find the filter assembly. I suspect someone may have bypassed it, but where would it be if it was still installed?
Thanks in advance !
Leigh
leigh8314bss is offline   Reply With Quote
Old 07-24-2019, 05:23 PM   #2
bikendan's Avatar
No such model as a 8413bss.
NADA shows a 8314bss for 2011. Is that what you have?
Equalizer WDH
Old 07-24-2019, 06:11 PM   #3
bikendan,
Yes, it's an 8314BSS.
Leigh
Old 07-24-2019, 06:16 PM   #4
Do you know where the water pump is (listen when it's running). Most likely right next to the pump. May be in a compartment closed off by a door with a hinge where the latch should be. Remove two screws from the hinge and open door.
Should be close to the City Water inlet on the outside so look around inside in the same approximate location.
Sami. my Shih-Tsu "Co-Pilot" R.I.P
Politically Incorrect since 1943
"Sometimes you're the dog, sometimes you're the tree"
2004 Nissan Titan
Old 07-25-2019, 04:49 AM   #5
fonzie's Avatar
Have a look below your television, bottom door on the left, open by removing screws on one set of hinges. Water filter should be there.
Fonzie
Nights Camped:2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36) 2017 (32) 2018 (42)
Old 07-26-2019, 09:28 AM   #6
I have a 2011 8319SS and my water filter is under the tv behind a hinged cupboard door.
Madmax0527 is offline   Reply With Quote
Old 07-26-2019, 12:52 PM   #7
Smile
Thanks you everyone for your help. I did find it exactly where suggested. From reading the trailer manual it says it filters both the fresh water and from the campground connect. The fellow I bought the trailer from didn't seem to know what the large plastic wrench was for. Kinda makes we wonder if he know there was an inboard filter. Seems it's important to know for winterizing. Also, is there an owners manual specifically for the 8314BSS which would give specifics about where things are located etc?
Thanks!!
Old 07-26-2019, 01:08 PM   #8
bikendan's Avatar
Thanks!!
Nope, no such things exists in the RV Industry. Maybe a handful of boutique RV manufacturers that don't make many.
A generic owners manual has been the standard for many years.
Equalizer WDH
Old 07-26-2019, 01:24 PM   #9
fonzie's Avatar
You can download a generic manual here.
Forest River Forums - Downloads - 2010 Forest River Generic Manual
Fonzie
Old 07-26-2019, 03:10 PM   #10
Enjoying Life
Thanks!!
Don't forget to open a faucet before trying to remove canister. It will be pressurized and almost impossible to move. Also, have small bucket or towels underneath to catch the overflow when opening.
2019 Rockwood 2608BSD 2019 F250 4x4 6.2
ďLife should not be a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside in a cloud of smoke, thoroughly used up, totally worn out, and loudly proclaiming "Wow! What a Ride!Ē - Hunter S. Thompson, The Proud Highway: Saga of a Desperate Southern Gentleman, 1955-1967
TeachTexas is online now   Reply With Quote
Old 07-26-2019, 03:31 PM   #11
RangeMaggotBob's Avatar
Leigh- what TeachTexas says is VERY important. Clean up ANY spilled water. Water is the RV owner's worst nightmare. Even a little bit draining into the floor behind a cupboard door.
2015 Forest River Rockwood Signature Series Ultra Lite 8289WS w/Diamond pkg.
2014 RAM CTD 6.7 Tradesman 4WD Auto Crew Cab Long Bed
Honda eu2000i generators
RangeMaggotBob is offline   Reply With Quote
water, water filter
