09-28-2015, 11:44 AM
#21
Two AC's are going to do you no good without 50 amp service. You are looking at a fortune to upgrade a used trailer to 50 amp service and adding a second AC. We have one 13.5 AC and get by. It may be 88 inside the trailer at times, but that is better than 105 and it cools down pretty fast after the scorching sun goes down.
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
09-28-2015, 02:11 PM
#22
I've read some guys have installed a second AC and put it on a separate 20A circuit so they use 2 shore power cords when they camp, a 30A and a 20A but you're right to modify the power system on the camper to be 50A instead of 30A seems like it would be very expensive.
Jack and Jan
Nights camped 2014 - 8 | Nights camped 2015 - 23 | Nights camped 2016 - 24
2015 Ford Super Duty F350 > Blue Ox Swaypro WD Hitch > 2015 Rockwood Windjammer 3008W
10-09-2015, 05:39 AM
#23
MCTroy
Thank you for an answer to a big concern we have. We leave our two large dogs in the camper. We came back one hot afternoon to find the ac off. Breaker had tripped. They were fine but very warm and we were glad we got back when we did. We were trying to find a solution should the electric go out again. The 12v fan is a good idea. Thank you.
2015 Windjammer 3029 Diamond Edition
2018 Ram 2500
Ohio River Rat
10-09-2015, 07:23 AM
#24
I ordered mine with the 13.5, kinda wish I would have got the 15.0. Just because! Knowing full well that discharge air temperature is directly related to the relative humidity, I,m going to be operating an electronic dehumidifier to help pull some additional moisture out of the "cabin" and see if that doesn't improve the effiencency of the AC. The specs on the unit were 14 x8 x6, 6 lbs, rated for 2200 cu ft space, 2.6A,2 l cap. 20 oz/day at 80% humidity. Got it toward end of season when humidity was lower, but I can see it draws out the water. Now in fall season with heat on, I can see that the condensation on the windows is gone.
2016 Flagstaff 27VRL Emerald
14K Equalizer
2020 Silverado 2500HD CC 4X4 6.6L gas 3.73
10-09-2015, 02:04 PM
#25
Thanks everyone all for the great advice!
From all I have read, the A/C seems to be a personal choice for the most part. It seems everyone has different tolerances for heat and as it turns out my family and I keep our house around 78 degrees during the summer here in California and find that to be fine.
Having written that, we opted to get a single 15k BTU A/C because a dealer not too far away had a WJ3006WK on the lot with a 15k unit. It was at a great price, had all the options we wanted for sure and because heat doesn’t bother us too much we decided to go for it. If it would have had the 13.5k unit I would have passed.
2016 Windjammer 3006WK - Sold July 2018
2002 Lance Lite 835EC TC - Sold July 2015
2010 Dodge Ram 2500, 4x4, Diesel, Front Hitch, Air Lift 5000 Rear Air Bags, Sold Mar 2019.
MISSION COMPLETED!
10-09-2015, 03:17 PM
#26
Have WJ 2809 with one 15k unit; does good job & we are in NE Fla.
10-09-2015, 03:36 PM
#27
Georgia Rally Coordinator
Just remember the square footage of your camper will help you determine whether you need two ac or one. I have 3 slides there for I opted for the 2nd ac Best call I made. First V-lite only had two slides and one 15000 ac did fine but only two slides. Also ya got to remeber these things are no insulated like a house. Later RJD
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
10-09-2015, 03:56 PM
#28
In the heat of FL and TX one AC won't keep up.
Experience: at Flagler Beach the temperatures were above 100 in the shade. A single 13.5K ducted with my toy garage closed off and sealed would not keep up. The lowest it would pull it down to was 81 and that seemed like I shouldn't be running it that long. With the garage closed off it is like cooling a 22' trailer. Plus, I have added insulation under the entire floor and have Reflectix custom cut and ready for all windows. In that heat, I actually had it on all windows.
I will tell you how I plan to add a second AC if interested.
WW
Hyper Lite was sold
2017 F-250 4x4 6.2L Gas
10-10-2015, 05:00 AM
#29
Our rig is black (34RL Work and Play), so take that into account when considering my response.
We had a "no shade" campsite over the Labor Day weekend, we were in northern Michigan, but the temps got up near 90 degrees.
As soon as we got home I added a second A/C unit to the bedroom.
Ours is a 50amp unit, but was not pre -wired for second A/C.
http://www.forestriverforums.com/for...lay-93155.html
I may end up adding a 3rd unit, to the garage area? Time will tell.
Better to have it and not need it, than need it and not have it.
We take time to go on a camping trip, then can't sleep because it is too hot? Why risk it.
2007 Work & Play 34RL Toyhauler.
2003 GMC Sierra HD Dmax Alli.
10-11-2015, 05:48 AM
#30
I will "home run" with 12awg romex from the second AC to the utility access area and terminate on a weatherproof plug on the side, like the one we have; probably a 30A; eventhough it only needs 20A. You keep the RV on 30A, distribution panel, EMS, and all. Then buy or make a 50A male to two 30A female adapter; a Y adapter. The trailer plugs into one 30A female the AC into the other. The beauty of it is you can choose which 50A phase is best. There can be quite a difference in voltage on the phases. The cost, beside the AC unit, is a little 12awg romex, a male RV connection, a cord, the Y adapter, and maybe a little wire mold to hide any exposed romex. Easy Peasy.
WWW
Hyper Lite was sold
07-05-2016, 11:18 PM
#31
All has been well with the single 15k btu AC until today... We are in St Louis, arrived around 4pm in 90+ degree heat and the WJ did not cool down until the sun was almost down. So, I am thinking of adding a 9000 btu unit in the bedroom where the fantastic fan is located. So far all of the RV parks we have been to, have a 30amp and a 20amp next to each other, (when we get a 30amp service). Since the 9000 btu unit will run off a 15amp circuit, I will just run an extension cord to the 20amp outlet.
Anyone done this before? Is installing the unit in the bedroom vent just a matter of wiring and mounting, no mounting mods needed, just some wiring to get the 120vac to the vent opening?
In the next 2 days, going to go to the hardware store and buy some reflextix to install on the windows, I can tell that will help, I could feel the heat coming through the windows...
Thanks,
GECTisMe
Jody
MISSION COMPLETED!
07-06-2016, 06:20 AM
#32
MCTroy
You are right about the windows letting in heat. I made some black out curtains for our big window in the back. Also added the pillow like covers over the vents. This has helped keep the heat out and the cool in. In Ohio 90 degrees heat and humidity our 13000 single unit will keep the camper about 78 which is ok until evening then it drops to 75 where we keep it set.
2018 Ram 2500
Ohio River Rat
