Old 07-05-2016, 11:18 PM   #31
gectisme's Avatar
All has been well with the single 15k btu AC until today... We are in St Louis, arrived around 4pm in 90+ degree heat and the WJ did not cool down until the sun was almost down. So, I am thinking of adding a 9000 btu unit in the bedroom where the fantastic fan is located. So far all of the RV parks we have been to, have a 30amp and a 20amp next to each other, (when we get a 30amp service). Since the 9000 btu unit will run off a 15amp circuit, I will just run an extension cord to the 20amp outlet.
Anyone done this before? Is installing the unit in the bedroom vent just a matter of wiring and mounting, no mounting mods needed, just some wiring to get the 120vac to the vent opening?
In the next 2 days, going to go to the hardware store and buy some reflextix to install on the windows, I can tell that will help, I could feel the heat coming through the windows...
Thanks,
GECTisMe
Jody
2016 Windjammer 3006WK
2010 Dodge Ram 2500, 4x4, Diesel, Front Hitch, Air Lift 5000 Rear Air Bags, (not really used, left over from our truck camper). Equalizer E4 1.4k/14k WD Hitch. TST 507 TPMS. Furrion FOS48TA Observation Camera. Garmin RV-760 GPS. Honda 2000i Genny, PI EMS-PT30C.
MISSION COMPLETED!
gectisme is online now   Reply With Quote
Old 07-06-2016, 06:20 AM   #32
MCTroy
You are right about the windows letting in heat. I made some black out curtains for our big window in the back. Also added the pillow like covers over the vents. This has helped keep the heat out and the cool in. In Ohio 90 degrees heat and humidity our 13000 single unit will keep the camper about 78 which is ok until evening then it drops to 75 where we keep it set.
2015 Windjammer 3029 Diamond Edition
2011 Ram 5.7 hemi
Ohio River Rat
Hurry Spring 2018! We have plans ready!
MCTroy is offline   Reply With Quote
windjammer
