Old 09-16-2017, 10:22 PM   #1
Windjammer 3025w
Any one having problems with door catching.. We just bought it.. 2018.
Pm0393 is offline   Reply With Quote
Old 09-17-2017, 06:58 AM   #2
Zak1's Avatar
I have a 2016 VLite (same basic trailer as yours but made by Flagstaff) 30WIKSS and the bedroom
exterior door (the most forward of the two doors) and it sticks or catches as well?
Zak1 is offline   Reply With Quote
Old 09-17-2017, 07:04 AM   #3
Just while entering without the Slides deployed? When set up with slides deployed? Are you Level? Youroo!!
Old 09-17-2017, 07:04 AM   #4
Although I don't have the same model at all, my door was sticking from the factory as well. Turns out it was one of the screws holding the door frame in place. Little turn tighter and used a file on the head and the screen door frame and problem solved. Just something to look at....
j02kennedy is offline   Reply With Quote
Old 09-17-2017, 11:19 PM   #5
Im very close to level.. Still a little movement.. But door coming in to rv catches..
Old 09-17-2017, 11:23 PM   #6
ID:	151714Click image for larger version
Old 09-18-2017, 02:42 PM   #7
Half ton corvette moter and beefy trans temp never got above 203. Avg temp going from Ohio to Panama city Florida was 174.. Stopped twice to fill up with fuel.... Not bad pulled like a beast..
Old 09-18-2017, 07:00 PM   #8
retiredguy's Avatar
We've had the problem since new on back door. I just adjust the back stabilizer until it swing freely.
2013 Windjammer 3025
2018 Heartland trail Runner sle 265
2012 GMC 3500 6.6
2011 Razor 800
https://dougbevswanderings.blogspot.ca/
retiredguy is offline   Reply With Quote
Old 09-18-2017, 07:28 PM   #9
OK thank you sir
Old 09-18-2017, 09:18 PM   #10
Working kinks out of it's and it's very frustrating wobbly but stability is perfect I think slide out needs a little attention
Old 11-18-2017, 04:24 PM   #11
Novice Travel Trailer Guy
benchmarks's Avatar
Yes. Door is hard to open due to latch plate being screwed on to far back. I just took a file to the latch and it opens smoother now.
2018 Flagstaff Micro Lite 25BRDS Travel Trailer
2018 Chevrolet Silverado 2500 LTZ
benchmarks is offline   Reply With Quote
Old 11-18-2017, 06:04 PM   #12
TimVWulp's Avatar
Pm0393 I have a 2015 VLite (same basic trailer as yours but made by Flagstaff) 30WIKSS looks like you have the equalizer hitch. It looks like it is set up right to distribute the trailer weight to the truck front wheels. what weight range are the hitch bars? next year keep an eye on the seam for the darker metal skirt at the bottom of the trailer. I had to calk the seam as it started to crack open. I really like this floor plan and the build quality.
Tim
TimVWulp is offline   Reply With Quote
windjammer
