Old 05-21-2016, 11:53 PM   #21
So whatis involved with installing a second ac with a 30 amp panel?
Carrier is offline   Reply With Quote
Old 05-22-2016, 08:24 AM   #22
Timex's Avatar
What we have done in mid August with temps in the high 90's and 75% humidity:
Turn the AC as low as you can stand in the morning to get a head start on the day's heat.
Use an oscillating tower fan in the LR.
Slip a cut-to-fit piece of Reflectix between the day/night shade and the window panes of most or all of the (single pane) windows. Nothing to see outside anyways.
Keep movements to a minimum inside to not build up body heat.
If you cook, do it outside as much as possible.
I guess 1st of all, if you can, get a site with shade. As you see in the pic, our site had very little shade and we survived with 1 AC(15K BTU).
2012 Flagstaff V Lite 30 WRLTS
2005 Dodge Ram 2500 5.7 Mag Hemi 3.72 Rearaxle
Nights camped 2015 = 23
Nights camped 2016 = 25
Nights camped 2017 = 13
Nights camped 2018 = 3
Timex is offline   Reply With Quote
Old 05-22-2016, 02:17 PM   #23
Timex, all good points! By the way, that campground looks very nice, do you mind sharing where it is?
Carrier, Turbs sent us a link to another thread where he discussed how he installed his, I think he sent it to us via a PM. I'm not good with electrical, or I'd attempt to explain it to you, my DH did our installation. I imagine if you do a search that thread will come up -- I think he posted it either towards the end of last summer or the year before.
He had a 5'r and installed his new, smaller electrical box in his basement. Since we don't have the basement option, we ran ours over to come down through our pantry, which is on the wall in the galley and the reverse of that same wall is in our bedroom. This worked out well as everything is concealed within and no loose wiring is running within sight.
Deb
Windjam2 is offline   Reply With Quote
Old 05-22-2016, 02:38 PM   #24
Timex's Avatar
Deb
I failed to mention; the Reflectix is held in place by clothes pins clipped to the shades. We just roll them up and store in a cabinet when not in use.
The rv park is Coastal Haven just east of Fairhope, AL. They were having problems with their website so I guess they took it down. Just look it up on rvpark reviews.
Old 05-22-2016, 02:53 PM   #25
Witch Doctor's Avatar
good advice from Timex, but also I have 1 A/C and I try when traveling to be at a CG by 2 or 3:00 PM if i get in later it will not cool down until like 8:00 at night, I have camped a lot in Georgia and also in Florida during the hot humid summer months.....
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 05-23-2016, 03:48 PM   #26
RusLwt001's Avatar
Does anyone know if we can go to the forest river website, type in our seriL number, and find out if ours has a 13,500 or 15,000amp AC?
Thanks.
Deb
I'm pretty sure if you have only one AC its the 13,500 BTU. The 15,000 BTU is the second, optional AC for the 3025W. However, I think all of them are ready for a second AC install in the bedroom. In order to have the second AC it must have a 50 amp connection. The second AC will not run unless connected at 50 AMP.
Russ
2016 Rockwood Windjammer 3025W
Diamond Package
2016 Ram 2500 6.4 Hemi 4x4
RusLwt001 is offline   Reply With Quote
Old 05-23-2016, 04:07 PM   #27
Retired JSO's Avatar
If the area left or right of the install location is a closet or such, you can snake the wire overhead to that closet and down inside then either a flush mount external 20 amp plug on an outside wall or a male 20 amp cord end stubbed out the floor. I then used a 12 ga extension cord to the pedestal.
Retired JSO is offline   Reply With Quote
windjammer, air conditioner
