Old 06-06-2015, 10:58 PM   #1
jim
windjammer 3029w
I was wondering if anyone could tell me if these campers have galley tanks on them and how many gallons it it?
candace123 is offline   Reply With Quote
Old 06-07-2015, 07:29 AM   #2
D_B Travelers's Avatar
Candace, I am assuming you mean holding tanks? You didn't give the year, but most of the Windjammer trailers have about 40 gallons of fresh water capacity and just less than 40 for gray and black water tanks. The fresh water tank is located behind the axles so on the trip out you will be lifting some weight off of the tongue, but try to dump the other two tanks before leaving the camp site as they are located forward of the axle, adding undesired weight.
D_B Travelers - 8 nights in 2018, 58 nights in 2017. [U]1st love: 2014 TT WJ3001w, now 2016 40' FW SOB, 2015 GMC 3500HD CC DRW Duramax, TST 507rv TPMS.
"Happiness? A good meal, a good cigar and a good woman - or a bad woman; it depends on how much happiness you can handle."
George Burns (1896 – 1996)
D_B Travelers is offline   Reply With Quote
Old 06-07-2015, 07:44 AM   #3
According to WJ brochure, this model has 43 gal. fresh, 38 gal. gray & 38 gal. black. The models with front kitchens have 2 gray tanks for total of 76 gal. We have a 2809W with one gray tank & a friend has the2618W with 2 gray tanks.
Papa GLS is offline   Reply With Quote
Old 06-07-2015, 09:12 AM   #4
jim
That's what I'm asking guys the second grey tank is called a galley tank usually for the kitchen grey tank is for bathroom sink and shower and then black tank for toilet. The model I'm looking is a 3029w and is a 2015 but with no galley tank and a 38 gallon grey tank! That would get filled up in two showers and a load of dishes. I guess I will look for different models.
Old 06-07-2015, 09:21 AM   #5
candace123
The one you are looking at is pretty much a normal setup. The extra gray tank is not really that common, you just have to learn to use less water; not that difficult. Good luck whatever you decide.
Old 06-07-2015, 09:33 AM   #6
jim
candace123
Well that's what I was wondering, some models have galley tanks but they don't put in brochure. My big fifth wheel I have now has a galley tank and it was not in brochure when I bought it. So I have 70 gallon grey 40 galley 60 black. This would be a HUGE step down for me, if I went with this camper then.
Old 06-07-2015, 11:55 AM   #7
Hi I copied below Rockwoods windjammer trailer specification. The 3029 has only one 38 gal gray water tank for the kitchen and bathroom. The 3006WK 3008W 3025W have two 38 gal gray tanks or 76 gal of gray water total.
Hope this helps Tim
WINDJAMMER TRAVEL TRAILERS
Hitch Weight
UVW
GVWR
CCC
Exterior Length
Exterior Height
Exterior Width
Fresh Water
Gray Water
Black Water
Awning Size
3001W
738 lbs.
7261 lbs.
8760 lbs.
1499 lbs.
35' 1"
9' 10"
96"
43 gal.
38 gal.
38 gal.
18 ft
3006WK
915 lbs.
7328 lbs.
8932 lbs.
1604 lbs.
34' 7"
9' 10"
96"
43 gal.
76 gal.
38 gal.
21 ft
3008W
882 lbs.
6994 lbs.
8900 lbs.
1906 lbs.
34' 7"
9' 10"
96"
43 gal.
76 gal.
38 gal.
21 ft
3025W
971 lbs.
7550 lbs.
8930 lbs.
1380 lbs.
34' 7"
9' 10"
96"
43 gal.
76 gal.
38 gal.
21 ft
3029W
918 lbs.
7428 lbs.
8939 lbs.
1511 lbs.
35' 1"
9' 10"
96"
43 gal.
38 gal.
38 gal.
8 ft & 14 ft
Hitch Weight
UVW
GVWR
CCC
Exterior Length
Exterior Height
Exterior Width
Fresh Water
Gray Water
Black Water
Awning Size
3065WA
968 lbs.
7419 lbs.
8986 lbs.
1567 lbs.
34' 7"
9' 10"
96"
43 gal.
38 gal.
38 gal.
14 ft
GVWR (Gross Vehicle Weight Rating) – is the maximum permissible weight of the unit when fully loaded. It includes all weights at the unit’s axle(s) and tongue or pin, inclusive of all fluids, occupants, cargo, optional equipment and accessories. For Safety and product performance do NOT exceed the GVWR.
GCWR (Gross Combined Weight Rating) – The maximum total weight of the loaded unit, plus a tow vehicle. This includes the weight of both the unit and tow vehicle, fuel for each, all other fluids, cargo, occupants, optional equipment and accessories.
UVW (Unloaded Vehicle Weight)* – the typical weight of the unit as manufactured at the factory. It includes all weight at the unit’s axle(s) and tongue or pin and LP Gas. The UVW does not include cargo, fresh potable water, additional optional equipment or dealer installed accessories.
CCC (Cargo Carrying Capacity) ** – is the amount of weight available for all fluids, occupants, cargo, additional optional equipment and accessories. CCC is equal to GVWR minus UVW. Available CCC should accommodate fresh potable water (8.3lbs per gallon).
**Estimated Average based on standard build optional equipment.
Each Forest River RV is weighed at the manufacturing facility prior to shipping. A label identifying the unloaded vehicle weight of the actual unit and the cargo carrying capacity is applied to every Forest River RV prior to leaving our facilities.
Floor plans and specifications are based on the latest product information. Forest River, Inc. reserves the right to make changes in drawings and specifications at any time without notice and assumes no responsibility for any errors in the site. The model number does not necessarily reflect the overall length of a particular unit.
TimVWulp is offline   Reply With Quote
Old 06-08-2015, 09:45 AM   #8
The 2014 2618W Windjammer had two grey water tanks. 38g each. One for the bathroom and another for kitchen.
http://www.rvguide.com/specs/forest-...mer/2618w.html
2014 Rockwood 2618W Windjammer
2014 F150 XLT S-Crew 4x4, 3.5L EB, 6.5' Box, Maxtow, 36g tank
SpaCityBulldog is offline   Reply With Quote
windjammer
