Old 06-03-2016, 02:41 PM   #11
D_B Travelers's Avatar
Not really off topic, but wouldn't it be nice if RV dealers actually had a set of scales that they could put under the tongue jack or pin on RV's? Give you a REAL weight BEFORE you bought the rig and found it was 25-40% heavier than stated on the specifications! Like I stated, my WJ was listed as 770# hitch weight and the CAT scales showed 1075# on the way home Day 1. 300# more than listed! With 934# as the listed hitch weight for the 3029w, I would wager a cold one that it will be close to 1200#, new, dry, and empty!
The other related issue is my dealership used the 770# to determine I needed a 1000# rated WDH ...I had to change it for a 1400# after I couldn't figure out why the TV wouldn't level up. I pitched such a fit about them not knowing better, they did refund the money on the first hitch and install.
D_B Travelers - 35 nights in 2016... so far. 54 nights in 2015. 2014 Rockwood Windjammer 3001W Diamond Pkg, 2015 GMC 3500HD CC DRW Duramax, Equalizer 14K hitch, TST 507rv TPMS.
"Happiness? A good meal, a good cigar and a good woman - or a bad woman; it depends on how much happiness you can handle."
George Burns (1896 – 1996)
D_B Travelers is offline   Reply With Quote
Old 06-04-2016, 09:29 AM   #12
2014 1/2 Chevy, 5.3 with 3.42 rear. I pull 2819VS Windjammer. Published 794# hitch weight, GVWR 7,794#. Set truck in tow mode, and cruise at 65mph. Truck has plenty of power. Still haven't pulled anywhere but in Texas.
___________________
MK Clark
2819VS Windjammer
MKClark is offline   Reply With Quote
Old 06-04-2016, 04:35 PM   #13
Smile Windjammer 3029
I got a 2015 Windjammer 3029W and tow it with 2013 Ford F-150 with V-6 Ecoboost with 3.55 rear end. Tows perfectly fine. I use Equalizer 4pt WDH 1200lb hitch and is easy to hook up and unhook. I use the built in Ford brake controller. Love the trailer!
Aggie Dad is offline   Reply With Quote
Old 06-04-2016, 07:50 PM   #14
Capt. Mike's Avatar
We towed a 2014 Windjammer 3008W with a half-ton truck on one trip before upgrading to a 2500 Siverado with 6.0L gas engine. Tow fine on flat ground, but we went through the mountains in North Carolina. 5.3L in that half-ton struggled going up, and felt like it was being pushed going down.
Can it be done? Yes. Would I continue to do it? Nope...but maybe that was because of the way we had the truck and trailer loaded. Can't say, but I just wasn't comfortable. With the 2500 Chevy, we towed that Windjammer over 20K miles, including through the Rockies, with no issues.
As far as a WD hitch, I'd recommend a 12,000 lb. Equal-I-Zer
Mike and Yvonne
and Sophie, the little white dog
2017 Columbus 320RSC
2015 Chevy Silverado 2500HD Duramax 4X4
“It's not how old you are, it's how you are old.”Jules Renard
"It's not the years...it's the mileage." - Indiana Jones
Capt. Mike is offline   Reply With Quote
Old 06-04-2016, 09:09 PM   #15
Timex's Avatar
Please, please don't anybody take this personal.
I'm sure just about any salesman will tell you sure that moped can pull that trailer.
And I'm sure there is a lot of members here that pull their trailers with a 1/2 ton and believe they have no problems. But my Vlite weighs 8400 lbs and it is about all my truck can handle. I wouldn't dare go into the big mountains with it pulling my TT. If you feel your 1/2 ton pulls your rig with no problems, so be it. Just get in a slam on brakes situation and see what that (box on wheels) behind you does to that truck.
Just my .02.
No attacks please, just personal opinions.
2012 Flagstaff V Lite 30 WRLTS
2005 Dodge Ram 2500 5.7 Mag Hemi 3.72 Rearaxle
Nights camped 2015 = 23
Nights camped 2016 = 25!
Timex is offline   Reply With Quote
Old 06-04-2016, 09:26 PM   #16
Georgia Frog Rally 2017
aceinspp's Avatar
X 2 all the way I tow a V-lite also with 2500 6.0 Chevy 4:10 gear. Never had an issue so far towing flat or mountains. Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days booked for 2016--60 missed by 2
Days camped in 2016 58
Days booked so far in 2017 37
Old 06-04-2016, 09:43 PM   #17
MCTroy
We love our WJ 3029, and we also like towing it with a3/4 ton Ram. Glad we had that on our trip to the Springtime Amish rally Friday. Someone STOPPED on the interstate when they couldn't get into their exit lane! The Ram had enough brake and weight the rig stopped straight and without any skidding. I don't want to think what would have happened with a maxed out TV.
2015 Windjammer 3029 Diamond Edition
2011 Ram 5.7 hemi
Ohio River Rat
2016 camping: Lost count, but never enough.
2017 reservations made!
MCTroy is offline   Reply With Quote
Old 06-04-2016, 10:02 PM   #18
Been there! 2014 Nissan Titan w/big tow package 9300lbs tow rating pulling 8000lbs TT. It towed well once I got balance and hitch right. That one day I had to slam on brakes do to car cutting off my stopping distance at a red light. Trailer just pushed me into the right turn lane, turning left did nothing for me. We were extremely lucky no one was in that turn lane. After that trip we traded for Super Duty.
2016 Ford F250 XLT 4X4 6.2L
Hensley Arrow
Nights camping in 2016: 19 nights
Miles traveled in 2016: 2,575
uhduh camping is online now   Reply With Quote
Old 06-04-2016, 10:45 PM   #19
Windjammer 3029
2500 HD
I own a 3029 and I wouldn't tow with a half ton. It behaves very well behind my 2500 HD. You will need sway bars. Be sure to get the fan in the kitchen. we regret that. Consider load range E tires also. Love the Windjammer
amforelectronics is offline   Reply With Quote
Old 06-05-2016, 08:51 PM   #20
Hendricks42091's Avatar
I have the 3029w and towing with a 2015 GMC Sierra. Pulls just fine and get better gas millage in my gaser than most diesels while pulling. Def need anti sway bars and a good weight distribution hitch. Weigh after you loaded so you know how much the true hitch weight on your truck is. You don't want to go over any limits which is possible if your not careful and paying attention.
2016 Forest River WindJammer 3029W pulled by 2015 GMC Sierra All Terrain 5.3 V8 EcoTech 3.42 axle ratio
Hendricks42091 is offline   Reply With Quote
tow vehicle, windjammer
