Old 06-07-2016, 07:29 AM   #21
nc-canuck's Avatar
Love my 3029w windjammer. Towing with a 2004 3/4 ton Suburban with the 8.1L engine and 3.73 gear ratio. Tow capacity is 12000 lbs. I use the squeekalizer 12,000 wd hitch. I have to agree with several others that a 1/2 ton would be putting you at the upper limits. I would not be comfortable towing with anything less than a 3/4 ton. Hitch weight stated for my 2016 is 934 lbs. loaded up for camping with empty tanks we come in at 1085 lbs. Was in the NC mountains over Memorial and was able to pull without an issue.
You probably could pull with a 1/2 ton but why put yourself and those around you at risk. This is a big heavy trailer.
2016 Rockwood Windjammer 3029W
2013 F350 Lariat Longbed 6.2L
nc-canuck is offline   Reply With Quote
Old 06-07-2016, 08:41 AM   #22
Originally Posted by lthouse101 View Post
Hi
New to the forum and RV'ing.
Contemplating purchasing a 3029W.
I intend to use a Chevy Silverado to haul with it.
It has a rated towing capacity of 9200 lbs.
Anyone else using a 1/2 ton to tow this trailer?
Also.. would you share your thoughts on a brake controller and anti-sway bars?
What ones you'd recommend or use.
Any suggestions and help would be much appreciated.
Thank you!
If you are asking about a "Brake Controller" then your Truck only has a Hitch,not set up with a "HD Trailering Package" it needs HELP plus "WD with built in SC"! You will find out Most 1/2 Ton owners will say"Oh yea I added Air Bags,Air Shocks,Super Springs,Sumo Stops,but it is Basically Stock"! Yes you can look around several sites for the OK to use your 1/2 Ton,but in your Heart and the Safety of your Family remove the Doubt and Go 3/4! Youroo!!
Old 06-10-2016, 03:20 PM   #23
You should have a 3/4 ton truck to pull this trailer. We towed our 3029 last year with an F150, max tow package, 11,200 lb capacity.
It was at max load capacity when towing. This year we have an F250, 6.2lL gas. While it has only 12,600 lb tow capacity, the load carring capacity of this truck is 3,300 lbs, almost twice the F150. The brakes are much better, and the truck is never overloaded.
Believe me, you'll feel much better with a 3/4 ton TV.
GaryHowe is offline   Reply With Quote
Old 06-25-2016, 09:08 PM   #24
Originally Posted by Capt. Mike View Post
We towed a 2014 Windjammer 3008W with a half-ton truck on one trip before upgrading to a 2500 Siverado with 6.0L gas engine. Tow fine on flat ground, but we went through the mountains in North Carolina. 5.3L in that half-ton struggled going up, and felt like it was being pushed going down.
Can it be done? Yes. Would I continue to do it? Nope...but maybe that was because of the way we had the truck and trailer loaded. Can't say, but I just wasn't comfortable. With the 2500 Chevy, we towed that Windjammer over 20K miles, including through the Rockies, with no issues.
As far as a WD hitch, I'd recommend a 12,000 lb. Equal-I-Zer
DITTO,DITTO!!
It pulled fine with my 2012 1/2T 5.3 342 around the flatter areas here in Michigan. But the minute you turned up hill the engine screamed! I knew then if traveling out of state the screaming would become and issue. Also, any uneven roads (which are plentiful in Michigan) gave us a the boat affect. Contemplated a new 1/2T Max with the 6.2 but the towing capability increase was minimal. Decided on the 3/4 6.0L all issues resolved.
wzpsjm is offline   Reply With Quote
Old 06-27-2016, 12:49 PM   #25
D_B Travelers's Avatar
How big of a trailer is...BIG?
It would be nice if there were a chart showing what TT a 1/2 Ton can pull, which ones need a 3/4 Ton, and so on. Unfortunately that would require a computer like NASA uses, be a nightmare to keep updated and would also require a huge matrix for how each truck was equipped. So, where is the break line for safely/comfortably towing, what length is okay, but more importantly what RV weight is the max? A 1/2 ton all decked out with HD towing, electric brake controllers, air bags, the correct WD hitch(set up properly), improved air flow, dash board hula girl, and the correct type of tires all are contributing factors to get a 1/2 ton to do a heavy job. We bought the WJ3001w after doing some real research and pulled it comfortably with a 5.3 GMC 1500, up and down 8,500' Wyoming/Colorado mountains last year, but only after adding K&N cold air and some expensive dual exhausts so it could breathe at higher altitudes. BUT, would it have been better pulled by a 3/4 ton? Without a doubt. We had just bought the truck in 2013 without the thought of pulling a trailer; and in 2014 we decided to buy a TT. Could not trading up for a new truck at that point. Lots of people get into this very predicament: already have a wonderful truck and really don't want to trade.
In the end it is a personal decision. Can you safely and comfortably pull model XX travel trailer with the truck you have currently, or do you need to look at a different (lighter) model? We did trade for a new GMC 3500HD Duramax DRW this year in anticipation of purchasing a 5th wheel in 2017. I bought heavier than I knew I would need so I didn't have to worry as much. If you are going to continue to RV, then perhaps trading trucks isn't that bad of an idea.
D_B Travelers - 35 nights in 2016... so far. 54 nights in 2015. 2014 Rockwood Windjammer 3001W Diamond Pkg, 2015 GMC 3500HD CC DRW Duramax, Equalizer 14K hitch, TST 507rv TPMS.
"Happiness? A good meal, a good cigar and a good woman - or a bad woman; it depends on how much happiness you can handle."
George Burns (1896 1996)
D_B Travelers is offline   Reply With Quote
Old 06-27-2016, 01:46 PM   #26
DB there is a program like that "Changingears.com",but like every other subject that comes up on a Fourm people say "That is NOT correct" so on we go! Youroo!!
Old 06-27-2016, 01:59 PM   #27
Georgia Frog Rally 2017
aceinspp's Avatar
There is a pretty good article in March Trailer Life that list Max tow ratings for almost 750 different trucks and SUVs. Give a good Idea when looking for a camper and the truck you have and what you can tow. Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days booked for 2016--60 missed by 2
Days camped in 2016 58
Days booked so far in 2017 37
Old 06-27-2016, 02:13 PM   #28
Yes, I downloaded and saved it as well as GM's Towing Guide, and some other tire related articles for future reference. Youroo stated that there is a program in Changing Gears, but like he said, people challenge it and go their own way.
Besides, if we took all the "can I pull this?", and "which tire should I get", or "which truck is the best" threads out of the forum, we would only have one page worth of postings left!
Old 06-27-2016, 02:16 PM   #29
aceinspp's Avatar
X 2 Later RJD
Old 06-27-2016, 08:36 PM   #30
Most of those towing guides are just that - towing. They usually don't discuss payload, which is usually what you impact first. Somebody with 2 kids, a wife and a dog has to get a TT with bunks, which are usually bigger/heavier than the couple alone would get. So the weight it already higher. Then they load the kids, wife, dog and STUFF into the TV and they're over on payload because all they thought about was towing capacity.
1988 Coleman Sequoia - popup (1987-2009)
2012 Roo19 - hybid (2012-2015)
2011 Traverse LT, 3.6L, FWD
2009 Silverado Ext Cab, 5.3L, 4x4, 3.73
rockfordroo is online now   Reply With Quote
tow vehicle, windjammer
