Old 10-12-2014, 04:22 AM   #1
Windjammer Bedroom Slideout
Hello All,
We are new to the forum and Forest River products. We have a 2015 Windjammer 2618 and the bedroom slide goes out crooked with one side dropping in and then the other. It has a single screw jack under the room and does not seem that it can it be adjusted. We are concerned that this will eventually cause the slide to fail. Has anyone else had this problem and was it resolved to your satisfaction? Thanks for any replies.
2015 Windjammer 2618W, Reese Stright-Line Hitch.
2013 Chevy 2500HD LTZ Duramax/Allison, Stock
Just Me & The Wife
Proud To Be An American
Max Windjammer is offline   Reply With Quote
Old 10-16-2014, 05:17 PM   #2
Anyone?
Just Me & The Wife
Old 10-16-2014, 05:33 PM   #3
Charles Firth's Avatar
I have the bedroom slide on my 3065w Jammer, no problems so far. Have you tried to manually move the slide out ? It really sounds like a warranty issue , something the dealer need to attend to. I've had only one warranty issue and it was handled well. I would not use the unit until its fixed. Good luck.
Chuck in Va
Charles Firth is offline   Reply With Quote
Old 10-16-2014, 05:39 PM   #4
Dazed & Confused
M&K Hoffman's Avatar
No problems with either slide on my 3008W!
And BTW
~Mike & Kim~
2014 Rockwood Windjammer 3008W Diamond Package
2020 Ram 2500 6.4L Crew cab 4WD, 4.10 Axel
M&K Hoffman is offline   Reply With Quote
Old 10-20-2014, 08:37 PM   #5
Aggie Family
Same TT - no problems with the slides. A warranty issue - hassle. Good luck.
Aggie Family
2015 Rockwood 2618W, 2-A/Cs 50 Amp
2014 F150 Ecoboost, S-CREW 157" WB, 6.5' box, Tow Mirrors, Maxtow, 3.73
Equalizer 4-pt WDH
2ags81 is offline   Reply With Quote
Old 10-20-2014, 09:03 PM   #6
Mobilemikey's Avatar
3029, no issue with our bedroom slide. It goes even in and even out.
1st year owner.
Rockwood Windjammer 3029w "Alpha Site"
Enjoying life while the kid is away... In College...
SOB Class A diesel pusher ...
Deciding if the full time lifestyle is for us...
Mobilemikey is offline   Reply With Quote
Old 10-21-2014, 06:44 PM   #7
Mathteacher's Avatar
No problems with the slide on our 3029.
Mike and Joyce
TT: 2015 Windjammer 3029
TV: 2010 GMC Sierra 2500
Mathteacher is offline   Reply With Quote
Old 10-22-2014, 05:00 PM   #8
Thanks for the replies. It goes in to dealer on 10/28. Hopefully it comes out better then it went in.
Just Me & The Wife
Old 10-22-2014, 05:01 PM   #9
I see what you did there! Nice!
Anyway, good luck and et us know how it ends up.
Old 10-22-2014, 06:29 PM   #10
My 2015 Wind Jammer 3008 is doing something similiar. Can see day light when slides are in at all bottom corners. Bedroom slide is slightly crooked when moving and it has a couple of long deep groves now on the underside. Going in for warranty and hoping it is something simple.
Carrier is offline   Reply With Quote
Old 11-03-2014, 08:00 AM   #11
Grn_Mtns's Avatar
Our 3025 does the same thing. Our dealer took a look during the PDI and said that is how they are made to operate when they have just one screw turning them in. I do leave the bathroom door open as the slide will tear off the handle as it glides in. Just a lame construction detail from FR. Still very reliable overall. A Look on the bright side : You not to have the lippert slide system to deal with!
Best,
Grn_Mtns
____________________________________
2018 8329 SS Rockwood /260watts solar
Grn_Mtns is offline   Reply With Quote
Old 11-03-2014, 09:01 AM   #12
Witch Doctor's Avatar
Don't have a wind jammer but had a similar Problem. Found that the screw heads where to high in the neoprene glide stripes, took them off and countersunk the screw whole. Also had the problems in the corners when the slides are in. There is a half rd. piece of foam (can't think of a better way to explane it) well anyway its held on by 2 screws move that forward to the trailer. That might save you a trip in the dealer. That piece closes off the corners. I then repainted the bottom scars to protect the wood with black enamel paint.
Coachmen M/H
Concord
2018 / 300 DSC
Old 11-03-2014, 09:23 AM   #13
What (Slide System) are in the units you are referring to if Not Lippert? Youroo!!
bed, bedroom slide, roo, slide, windjammer, slide out
