Old 12-18-2017, 03:05 PM   #1
2017 Windjammer 3029w
Windjammer Control Panel App?
I was glancing through my sales book for my 2017 Windjammer 3029w and in the book it shows that the control panel has an app in the app store and Google Play. I looked in the Apple App store and could not find anything. Never realized it was supposed to be an option but could be useful possibly if available. Anyone know, see or use an app? Am I missing something?
ID:	158613   Click image for larger version
Nederland, Texas
Dastagg is offline   Reply With Quote
Old 12-18-2017, 04:23 PM   #2
The app is called iRV Controller. It is in the Apple App Store.
2017 Rockwood Windjammer 3006WK
dankirk is offline   Reply With Quote
Old 12-18-2017, 04:50 PM   #3
THank you. I did find that one (later) and to try it out, I never could get it to connect. It seemed to find a bluetooth connection other than the iRV66 with showing a TP33 as available when close but will not connect in settings. Can connect with the iRV66 and works with the audio box fine, close it out but will not connect to the PP33 which may or may not be the correct item. I see no pairing button or instructions anywhere.
Nederland, Texas
Old 12-18-2017, 05:13 PM   #4
Did some googling and appears the TP33 is the correct signal and appears others have had similar issues with no real fixes to making it work. Thought it would be nice to open slides while watching outside close by to insure all is well while opening. Guess I may have to stick with watching while wife opens and holler if needed to stop. Found others in app reviews that said app worked then stopped at some point. No updates to app in a year.
Nederland, Texas
Old 12-19-2017, 01:46 PM   #5
Bluetooth
I had a similar issue using Android when I first got my camper.
It would try to connect and then disconnect.
I did a web search and found the panel had some early software issues, my dealer contacted Forest River and sent me a new panel.
It was easy to install and worked right away.
Check with your dealer and get a new panel.
brfriend is offline   Reply With Quote
Old 12-19-2017, 03:47 PM   #6
Rookiewood's Avatar
irv controller app working???
2016 Chevrolet Silverado 2500HD LTZ Z92
Rookiewood is offline   Reply With Quote
Old 12-19-2017, 04:27 PM   #7
App
Yes the Android app worked but I had to remove it and install an updated version as well.
They mentioned a compatibility issue with the updated Android software.
Old 01-02-2018, 08:47 PM   #8
primo20's Avatar
i should try and swap out my panel i guess. i have no issue connecting with the panel, but once i leave the doorway, the panel disconnects, and i have to repair. im using an iphone 6s plus. and the proper version of the app.
primo20 is offline   Reply With Quote
Old 03-25-2018, 12:56 PM   #9
The Bluetooth quit working in my control panel, all other functions work great. I called Nelson at Patrick Industries and they are sending a replacement panel. Excellent customer service!!!
Old 03-25-2018, 01:24 PM   #10
Shop replaced my panel and all works great. I have to be right next to the panel to connect, but then I can go outside and operate the slides while watching to insure everything is clear. Love it!
Nederland, Texas
windjammer
