05-20-2016, 09:09 PM
MCTroy
Windjammer learned a new trick
So this past weekend we were camping in Indiana and it was cool. We had good 30 amp service so we had the fireplace heater on with the TV. not much else was on electric and the water heater was on propane. I decided to risk tripping a circuit to use the microwave for a few seconds. As soon as the MW came on, the fireplace shut off. Not the TV or anything else and no tripped circuits. When the MW was done, I turned the fireplace back on and it worked fine. Of course, we had to test this new trick. So the next morning, I did the same thing: TV on, fireplace heater and added the coffee pot. Started the MW and off went the heater. Could there be something in the converter doing this? At our summer site, I tripped the 30 amp circuit outside at the power pole a couple of times - usually the AC and MW pulling too much juice. And there we know there isn't full 30 amp service. So why did the fireplace cut out like this?
thanks!
2015 Windjammer 3029 Diamond Edition
2018 Ram 2500
Ohio River Rat
05-20-2016, 09:24 PM
I keep thinking about this, but have no answer. Interesting though.
Tuckerdog1
2016 RAM 2500 Cummins SLT Lone Star 4X4 LB
2016 Windjammer 3029W Platinum
I'm not an expert. But I play one on the internet.
You live & learn or you don't live long.
If you don't punish your children, life will.
05-20-2016, 09:46 PM
Dazed & Confused
thanks!
Because running the fireplace and the microwave at the same time will have you over loading the system. A minute or so after the microwave shuts off I can hear a beep on ours when the relay resets.
~Mike & Kim~
2014 Rockwood Windjammer 3008W Diamond Package
2020 Ram 2500 6.4L Crew cab 4WD, 4.10 Axel
05-20-2016, 09:53 PM
MCTroy
Thanks! Good to know the WJ has this protection built in. I don't usually run the fireplace heater and MW at the same time. We didn't hear the beep but with the TV on we could have missed it or thought it was still the MW.
2018 Ram 2500
Ohio River Rat
05-21-2016, 08:06 AM
Fireplace Test
We have a Windjammer and I keep telling the wife why is that fireplace shutting itself off. Well I just did the microwave test and yup the fireplace shut down. So at least I have an answer for why. Thanks McTroy and we will see you guys in a couple weeks at the Amish FR rally.
05-21-2016, 01:32 PM
The fireplace definitely shuts off when the microwave is turned on. Too much amperage for the circuit breaker. No big deal.
05-21-2016, 01:41 PM
Excellent information. Thanks
2012 Rockwood Windjammer 3008 W
2020 Tundra Dbl Cab 4X4 SR5
05-21-2016, 05:07 PM
It's the same way on our 8329 ss
Rockwood signature series 8329SS Diamond package. Permanent campsite.
05-21-2016, 05:13 PM
Dazed & Confused
I would think any unit having a fireplace and a microwave on a 30 amp hook-up would have the feature. According to the monitor for my Progressive surge protector the microwave draws 15 amps and if the fireplace on high is usually 12 amps. Circuit breakers are only supposed to see continuous current at 80% of their rating, or with 30 amp circuits = 25.5 amps.
~Mike & Kim~
05-21-2016, 05:19 PM
On my Vlite I have a switch near the entrance door that flips 1 way for fireplace and the other for the MW. Can't run both at the same time of course. With it switched to FP, the MW is totally shut off, not even a clock showing.
2012 Flagstaff V Lite 30 WRLTS
2005 Dodge Ram 2500 5.7 Mag Hemi 3.72 Rearaxle
Nights camped 2015 = 23
Nights camped 2016 = 25
Nights camped 2017 = 13
Nights camped 2018 = 3
05-21-2016, 06:12 PM
Same with my Windjammer 3065w, a toggle switch to the left of the door below the main power switches . You either have the fireplace or the microwave, I can't do both. The switch will not let you. Its not an issue with me, just have to remember the switch.
Chuck " still in Va "
2012 3065w Windjammer
2012 f250 lariat Crew cab power stroke (of course )
05-21-2016, 06:16 PM
Georgia Rally Coordinator
I have 50amp on my camper have not seen this happen yet. Later RJD
2018 Dodge Ram 2500 6.4 3:73 gearing. Traded 2015 Chevy 2500 6.0, 4:10
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
05-21-2016, 06:25 PM
My Windjammer is 30 amp. The switch is only hooked up to the microwave and fireplace. Everything else works as it should, I usually run my water heater on shore power. I can run the TV, fireplace, water heater the same time. Even the coffee pot works well. Maybe I should run the water heater on gas to help with the amp draw.
05-21-2016, 06:41 PM
BRAG, BRAG!
05-21-2016, 07:15 PM
Not bragging just came that way as Ihave two ac. And your just jealous cause I have 50 Something one really needs to have in south. And I get to see ya at Bamaganza Later RJD
Days camped 2019 62
05-21-2016, 07:26 PM
And you are 100% correct!
05-21-2016, 07:29 PM
Never heard of that switch before; very interesting. Was that an add-on, or did it come new that way? I just looked at your model trailer, and that's one of the nicest floor plans I've seen on a TT. Very impressive, and if I ever went to a TT, I would be looking at that model.
2015 Forest River Rockwood Signature Series Ultra Lite 8289WS w/Diamond pkg.
2014 RAM CTD 6.7 Tradesman 4WD Auto Crew Cab Long Bed
Honda eu2200i generators
05-21-2016, 08:05 PM
Why thank you for the compliment!
And yes, the switch was OEM.
05-23-2016, 08:51 AM
The 3008W has no such switch, the fireplace kicks out as soon as you start the microwave I have never heard a beep and it does not trip the breaker. It is just something we noticed on day 1 and never thought twice about it, we usually turn off the fireplace first but sometimes we forget and it just goes out on its own and turn it on when we are done.
Phil
2017 Ford F-350 Lariat Crew Cab 6.7L Powerstroke
05-23-2016, 09:07 AM
Ours does the same thing. I read somewhere that the MW and the fireplace are on the same internal circuit.
2016 Rockwood 2703WS Sapphire
2016 F250 SD 6.2L
