Old 05-20-2016, 09:09 PM   #1
MCTroy
Windjammer learned a new trick
So this past weekend we were camping in Indiana and it was cool. We had good 30 amp service so we had the fireplace heater on with the TV. not much else was on electric and the water heater was on propane. I decided to risk tripping a circuit to use the microwave for a few seconds. As soon as the MW came on, the fireplace shut off. Not the TV or anything else and no tripped circuits. When the MW was done, I turned the fireplace back on and it worked fine. Of course, we had to test this new trick. So the next morning, I did the same thing: TV on, fireplace heater and added the coffee pot. Started the MW and off went the heater. Could there be something in the converter doing this? At our summer site, I tripped the 30 amp circuit outside at the power pole a couple of times - usually the AC and MW pulling too much juice. And there we know there isn't full 30 amp service. So why did the fireplace cut out like this?
thanks!
2015 Windjammer 3029 Diamond Edition
2011 Ram 5.7 hemi
Ohio River Rat
Hurry Spring 2018! We have plans ready!
MCTroy is offline   Reply With Quote
Old 05-20-2016, 09:24 PM   #2
tuckerdog1's Avatar
I keep thinking about this, but have no answer. Interesting though.
Tuckerdog1
2016 RAM 2500 Cummins SLT Lone Star 4X4 LB ( Mine )
2015 Genesis 5.0 ( Hers )
2016 Windjammer 3029W Platinum ( Ours )
I'm not an expert. But I play one on the internet.
You live & learn or you don't live long.
tuckerdog1 is offline   Reply With Quote
Old 05-20-2016, 09:46 PM   #3
Dazed & Confused
M&K Hoffman's Avatar
thanks!
Because running the fireplace and the microwave at the same time will have you over loading the system. A minute or so after the microwave shuts off I can hear a beep on ours when the relay resets.
~Mike & Kim~
2014 Rockwood Windjammer 3008W Diamond Package
2012 Toyota Tundra Doublecab 5.7 4WD
M&K Hoffman is offline   Reply With Quote
Old 05-20-2016, 09:53 PM   #4
MCTroy
Thanks! Good to know the WJ has this protection built in. I don't usually run the fireplace heater and MW at the same time. We didn't hear the beep but with the TV on we could have missed it or thought it was still the MW.
2011 Ram 5.7 hemi
Ohio River Rat
Old 05-21-2016, 08:06 AM   #5
Fireplace Test
We have a Windjammer and I keep telling the wife why is that fireplace shutting itself off. Well I just did the microwave test and yup the fireplace shut down. So at least I have an answer for why. Thanks McTroy and we will see you guys in a couple weeks at the Amish FR rally.
jblane56 is offline   Reply With Quote
Old 05-21-2016, 01:32 PM   #6
The fireplace definitely shuts off when the microwave is turned on. Too much amperage for the circuit breaker. No big deal.
Magdeep is offline   Reply With Quote
Old 05-21-2016, 01:41 PM   #7
buffalohunter's Avatar
Excellent information. Thanks
2012 Rockwood Windjammer 3008 W
2007 Tundra Reg Cab 4X4 SR5 5.7L
buffalohunter is offline   Reply With Quote
Old 05-21-2016, 05:07 PM   #8
It's the same way on our 8329 ss
Rockwood signature series 8329SS Diamond package. Permanent campsite.
rockjohn is offline   Reply With Quote
Old 05-21-2016, 05:13 PM   #9
Dazed & Confused
I would think any unit having a fireplace and a microwave on a 30 amp hook-up would have the feature. According to the monitor for my Progressive surge protector the microwave draws 15 amps and if the fireplace on high is usually 12 amps. Circuit breakers are only supposed to see continuous current at 80% of their rating, or with 30 amp circuits = 25.5 amps.
~Mike & Kim~
Old 05-21-2016, 05:19 PM   #10
Timex's Avatar
On my Vlite I have a switch near the entrance door that flips 1 way for fireplace and the other for the MW. Can't run both at the same time of course. With it switched to FP, the MW is totally shut off, not even a clock showing.
2012 Flagstaff V Lite 30 WRLTS
2005 Dodge Ram 2500 5.7 Mag Hemi 3.72 Rearaxle
Nights camped 2015 = 23
Nights camped 2016 = 25
Nights camped 2017 = 13
Nights camped 2018 = 3
Timex is offline   Reply With Quote
windjammer
