Old 08-21-2015, 02:23 PM   #1
Windjammer owners
Do any of you WJ owners use the Anderson levelers & if so how well do they work? Also do you have to trim them to get them to fit between the tires? Could not use them on my Micro Lite, but maybe I can on my WJ2809W.
Papa GLS is offline   Reply With Quote
Old 08-21-2015, 02:28 PM   #2
Alleged curmudgeon
Vern's Avatar
I don't use them, but the online (YouTube) video here
shows them being applied to a tandem axle trailer with wheel spacing similar to my Windjammer.
Lee
2013 Windjammer 3008W
2006 Chevy Silverado 2500HD 6.0L w/Equalizer 4
Nights camped: 2012 (29); 2013 (26); 2014 (40); 2015 (43); 2016 (35); 2017 (34)
Vern is offline   Reply With Quote
Old 08-21-2015, 02:48 PM   #3
Yes we use them but my husband had to cut then to fit between the tires.
CLewis is offline   Reply With Quote
Old 08-21-2015, 05:15 PM   #4
Don't have a Windjammer, but like the Anderson for the Minilite. I too had to cut 4" off one to fit between the tandem. Good if you need a lift over 1" because the one you have to cut starts about there. Also saves time.Need someone outside to watch the level and get the chock under while the driver keeps a foot on the breaks. It's like a ramp so any movement before the chocks are in place can change your level.
Freetyme1 is offline   Reply With Quote
Old 08-23-2015, 12:34 AM   #5
used mine at Goshin rally. I have two of them for both wheels on the same side of unit. One of the leavers will need have about 3" cut off on the leading edge so you can put it between the two wheels. Very happy with them.
Hope this helps Tim
TimVWulp is offline   Reply With Quote
Old 09-01-2015, 08:01 PM   #6
Anyone ever figure out why the Windjammer's tires are so close together?? I mean I can barely put my arm between those tires...
billb800si is offline   Reply With Quote
Old 09-01-2015, 08:22 PM   #7
About the same as my Mini-Lite? 2-1/2 inches.
2011 Traverse LT, 3.6L, FWD
windjammer
