Old 09-14-2012, 10:14 PM   #41
kaferman's Avatar
I bought the steady fast system, and yes there is a wood strip on the frame rails. I have mixed results with it. On concrete pads, 50% bounce removed. Grass or gravel, maybe 40%. The electric stabs are the main culprit as you can't get that extra "oomph" you can with manual jacks. A call to the company agreed with that also. It is better with it, but I am tempted to remove the electric stabs..
Windjammer 3006w is my model
2012 Ram Laramie Longhorn 4x4 2500 6.7L Cummins
2012 Windjammer 3006W
12K Equi-lizer WD Hitch
kaferman is offline   Reply With Quote
Old 09-14-2012, 10:58 PM   #42
Timex's Avatar
Has anybody contacted FR about this problem? Are they are aware of it, and have they come up with a remedy?
Timex is offline   Reply With Quote
Old 09-15-2012, 08:42 AM   #43
Lanningjw's Avatar
Thanks for the info on the wood strip on the frame rail. Did you have to use longer bolts and shim when you did the attachment to the rail?
I have the manual jacks on my jammer so maybe I will get better results.
How long was your install time?
Jim
2012 Windjammer 3001W
2010 Roo 19 (traded in)Mustang pop up (Sold)
1,000/10,000 equalizer
2000 Lund fishing Boat/2005 King Ouad 700 ATV
Windjammer lives at a Resort in Northern Minnesota. Lots of walleyes!
Lanningjw is offline   Reply With Quote
Old 09-15-2012, 08:57 AM   #44
kaferman's Avatar
They did send me longer bolts, and I remember making a shim on one . It took me about 4-5
Hours, as I took extra time trimming the underbelly liner. Be sure to seal up wherever you need to cut for the brackets to fit. They were very helpful on the phone. Called him on a Sunday and the answered all questions
Old 09-15-2012, 09:18 AM   #45
Road-King's Avatar
IMO it's more of an annoyance then a problem. I can live with it, if need be. I contacted FR about using slide out supports (see post #25).
Russ & Kim
2014 Alpine 3600RS
2007 Dodge Ram 3500 5.9 4X4
2008 Harley Davidson Road King 105th Anniversary
(2011-5 bad year)(2012-40)(2013-45)(2014-23)
Road-King is offline   Reply With Quote
Old 09-15-2012, 10:05 AM   #46
Timex's Avatar
Let me ask, does the trailer settle/lean to that side when you are in the slide or does it do it over a period of time? And does it "bounce" back to level? Are the stabilizer jacks "leaking" to the point where you have to tighten them up frequently?
Old 09-16-2012, 09:07 AM   #47
TTforTwo's Avatar
Good sidenote about the manual jacks vs electric stabilizers. I am looking at new TT's and was looking forward to electric stabs. But to have the least movement, you would recommend manual?
TTforTwo is offline   Reply With Quote
Old 09-16-2012, 09:26 AM   #48
Dave_Monica's Avatar
They're the same style jack as the manual with a motor drive on them.
Dave
Old 09-16-2012, 09:27 AM   #49
kaferman's Avatar
The electric ones are "neat", but that is all. You can get more torque on a manual scissor style. Also, there is one button for front and one for the rear. When you are lowering the jacks, you have to stop go to other side, position the blocks, go back lower some more, go back reposition, etc. With manual jacks, you crank near the block, so in my opinion manual is faster. Bells and whistles are nice, but after having manual an electric, I am going back to manual on the next one.
Old 09-16-2012, 09:32 AM   #50
My rear electric jacks are "self adjusting" and will "park" one side when it hits the ground until the other hits the ground and then lift the trailer together.
X2 on what Dave says, the electric jacks are just manual jacks with a motor added. I much prefer the electric.
v-cross, v-lite, windjammer
