Old 10-04-2013, 09:04 AM   #1
Windjammer Tank Heater Switch - No light
Not quite ready to winterize the trailer, and the temps are supposed to drop to 20 degrees tonight. So the furnace is on but when I turn the switch on for the tank heater, it doesn't light up like the water pump and water heater switches do. Checked breakers and fuses and all looks good.
How can I tell if the tank heaters are on?
Thanks,
Scott
2015 Keystone Raptor 425TS full body paint
TV 2015 RAM 3500 MC 4x4 DRW w/ AC69RC HD Trans
Pullrite Superglide 2300 24k w/ OE adapter 25k
cobiker is offline   Reply With Quote
Old 10-08-2013, 09:37 PM   #2
Pull the panel and look at the switch. A multimeter will confirm voltage across the contacts.
Compare the tank heater switch with the lighted water pump switch; if the tank heater switch has two wires, the water pump three, it's because the tank heater switch does not have a light.
boatsNtrees is offline   Reply With Quote
Old 10-08-2013, 10:54 PM   #3
Professional Curmudgeon
It's possible the tank heaters are thermostatically controlled and do not come on until the temp drops to freezing. Waiting for that to happen could put you in a bad position if they really aren't working, though.
2002 Forest River Flagstaff 8528RLS
2014 Coachmen Catalina 253RKS
2016 Keystone Summerland Mini 1750RD
2012 F250 Lariat 6.2L Crew Cab FX4
wrvond is offline   Reply With Quote
heater, light, tank, tank heater switch, windjammer
