Old 05-26-2014, 07:48 PM   #1
fil564's Avatar
Windjammer Tongue Height at level
Does anyone know offhand the tongue height of the Windjammer at level? We have a 2014 3008W and while it is in storage I wanted to check the hitch set up here so when I go get it I do not have to mess with it too much to get going. I think the truck is squatting too much in the rear when it is hooked up.
Phil
2012 Ford F-350 Lariat Crew Cab 6.2L FlexFuel
2014 Rockwood Windjammer 3008W
fil564 is offline   Reply With Quote
Old 05-26-2014, 09:20 PM   #2
MMCM/SS
What kind of hitch do you have?
Tooters is offline   Reply With Quote
Old 05-27-2014, 10:22 AM   #3
fil564's Avatar
It is just a standard Reese WD Hitch with an adjustable head that tilts.
Phil
Old 05-27-2014, 10:50 AM   #4
Alleged curmudgeon
Vern's Avatar
depends?
Phil...I'd be hesitant to rely definitively on anyone else's measurement since it is my sense the units may vary depending upon the axles used and the factory's installation setup for a particular manufacturing run. My 2013 3008W (manufactured April 2012) was recently recalled for the installation of a riser kit at the axles to provide needed wheel well clearance above the tires. It may be a false assumption to think the setup is not the same every time the factory runs the Windjammers. In my own case, my answer today would be about 4 inches higher than if you asked six months ago.
Lee
2013 Windjammer 3008W
2006 Chevy Silverado 2500HD 6.0L w/Equalizer 4
Nights camped: 2012 (29); 2013 (26); 2014 (40); 2015 (43); 2016 (35); 2017 (34)
Vern is offline   Reply With Quote
Old 05-27-2014, 11:03 AM   #5
BiigDaddy's Avatar
Just for kicks: My Rockwood 8327SS Has a top of hitch height of 22.5", and my receiver is set at 23.75" top of ball. Maybe you'll get lucky since they're somewhat similar....
2013 GMC Savana 2500 FBI Edition
2015 Rockwood 8327SS stuffed with 5 kids!
SE Michigan
Nights camped 2014: 48
BiigDaddy is offline   Reply With Quote
windjammer
