Hello all
I can not find the location for the power switch for my HD antenna in my 2019 Rockwood 8298WS. DW is crazy with only 3 channels. LOL Please help!!!!
There will be a wall plate that is normally behind the living room tv or the bedroom tv, that has a push button on it with a small led light. Push the button to turn on the local antenna per amp power. The led light should be on. If you are using the campground cable tv connection on the outside of your unit, the led light need to be off.
Go to the tv setup menu and insure the tv is set to antenna. Then scan the TV for the local channels, when done you should be all set.
Chuck & Sandra
Engineer/Teacher
2010 F350 CC 6.4
2015 Prime Time Sanibel 3601
