Old 11-17-2014, 01:34 PM   #1
Winter battery maintenance
Does everyone remove the battery from your travel trailer when laying up for the winter? We live in Southern Ontario and can have spells of well below freezing at times. Our trailer sits outdoors in our driveway. I am thinking if I watch the battery monitor and plug the trailer in when it shows less than 12 volts I should be okay. Does this make sense? I also make sure to use the battery disconnect switch.
chaslorr is offline   Reply With Quote
Old 11-17-2014, 01:43 PM   #2
KenHwy61's Avatar
This same discussion is going on at another thread and the general consensus there seems to be it is better to remove the battery than worrying about it.
Seasonally in the Grand Marias, MN campground
On the beautiful shores of Lake Superior
Aviator Wright-Flyer#1908
2012 Ram 2500HD CTD
KenHwy61 is offline   Reply With Quote
Old 11-17-2014, 02:00 PM   #3
fonzie's Avatar
Read these....your choice....I remove mine from trailer.
https://www.google.com/search?q=wint...com&gws_rd=ssl
Fonzie
Old 11-21-2014, 12:49 PM   #4
deartruc's Avatar
I haven't yet but normally will. Southern New England means the thermometer heads south for the winter. We get plenty of nights well below 0f. Though this is the first winter with our 23ikss (which means no access to the kitchen or rear of the trailer without sliding it out)
2017 GMC Yukon
2015 Roo 23 ikss
deartruc is offline   Reply With Quote
Old 11-21-2014, 12:56 PM   #5
hkreck's Avatar
I have left the batteries in the MH for the last 2 Winters, I keep it plugged into a 120 outlet with a surge protector on it. Last year was pretty cold for awhile but didn't have any problems. MH is parked in the driveway at home where I can check on it regularly.
Henry & Tena
2013 Solera 24S
The Great Escape
hkreck is offline   Reply With Quote
Old 11-21-2014, 01:47 PM   #6
BruceM's Avatar
It is my understanding that a battery will freeze only if it is in an extreme state of discharge.
Just keep it charged up and you'll be fine.
If it was not good to leave it in out the RV than what about all the vehicles parked outdoors during the winter?
2015 Rockwood MiniLite 2109S
2018 Ford F150, 3.5L ecoboost
Blue Ox SwayPro hitch
BruceM is offline   Reply With Quote
Old 11-21-2014, 02:08 PM   #7
ColoradoRick's Avatar
Yes, I bring mine into the garage and keep on the top of a few pressure-treated boards. (You never want to put batteries directly on concrete.) Three reasons:
-Batteries and propane tanks have a high-rate of theft in RV storage lots....only takes a few minutes for thieves to gather up a LOT of them.
-It can get -20 F here and I take turns plugging each battery in to my battery tender during the winter.
-I also get the propane tanks re-filled in the winter so when we start camping in the spring tanks are full and batteries are ready!
Rick & Karen
(Retired USAF, MSgt)
Monument, Colorado
6-year Travel Trailer RVers
2013 Forest River Rockwood Ultra-Lite 2904SS
2014 Toyota Tundra Maxcrew SR-5 TRD 4x4 (with Firestone airbags in the rear)
ColoradoRick is offline   Reply With Quote
Old 11-21-2014, 02:23 PM   #8
BruceM's Avatar
Will concrete harm a battery?
BatteryStuff Articles | Myth Busted. The Truth About Storing Batteries on Concrete Floor
Old 11-21-2014, 02:24 PM   #9
BruceM's Avatar
Some good tips here.
Does anyone use a hitch lock to prevent theft of the trailer?
Mine is parked in my driveway and I put on a hitch lock for extra security.
Old 11-21-2014, 02:52 PM   #10
Canonman's Avatar
Yes
Remove the batteries to an indoor (doesn't need to be heated) protected well ventilated area (garage). Buy and use a "Battery Tender", $40. Batteries will freeze if they are not charged. They are expensive and if you can get 3 years out of your RV batteries instead of 2 then they effectively cost you 1/3 less to own. $40 is 1/2 the cost of a battery and can help with any battery car, truck or RV. Well worth the money and time.
FR Wildwood 22 RKS
2007 1/2 Dodge 2500, Cummins 6.7
Retirement training completed
Currently enjoying second childhood
Canonman is offline   Reply With Quote
battery, maintenance, winter
