Old 11-13-2013, 09:25 AM   #1
winterize 2014 Rockwood 8325ss
I have a 2014 Rockwood 8325SS that comes with a winterize valve, however there is no directions on how to use this? Any help would be appreciated.
cccommpany is offline   Reply With Quote
Old 11-15-2013, 06:45 PM   #2
Paul & Sheri
pwb01's Avatar
You may be talking about a valve between the pump and the fresh water tank. You should see a hose connection outside labeled antifreeze. You might see another valve there too. Hook up a short hose to drop in a bucket of antifreeze, close the valve between the pump and tank, and open the one at the hose connection if there is one, turn on the pump and open each faucet until antifreeze comes out. Leave the valves all winter.
If you're talking about a valve at the hot water heater, that's there so you can drain the water heater and avoid filling it with anti-freeze. You probably have two or three valves there and you can google Hot water heater by-pass valves, match your configuration and set the valves for by-pass before you take the steps above to fill the lines with antifreeze.
2012 F150 F/X 4, 6cyl EcoBoost with Max tow pkg
2013 Rockwood 8280WS 5th wheel
2006 Sunline T1950
2004 T@B T-16
pwb01 is offline   Reply With Quote
rockwood, winter, winterize
