Old 11-30-2011, 11:51 AM   #1
Winterize for driving?
We'll be driving from Michigan to Arizona in January. As we're living in our 2304 now, we won't be winterizing it until we head south. But, will we need to, that's the question? When we stop at night, the trailer will be heated; the only time it will be exposed to the cold is in transit. We have heated tanks, so the risk would be to the pump. Any thoughts?
bdalejack51 is offline   Reply With Quote
Old 11-30-2011, 12:35 PM   #2
I don't think I would worry about it. If I remember right, pex pipe can take 10 degrees F for 24 hours without damage, with water in it. Noe for your traps, if it is very cold, when you stop for lunch, go in and turn on the furnace to 50 or so. Shut it off after lunch and good to go. AS for the tank heaters, good to have them at night, but I wouldn't run them while traveling. Moving liquid seldom freezes until it is very cold. The pump will take a while to freeze, and if you heat the trailer mid day, it will be fine.
Now all this is opinion. I have nor real experience doing this. Think about this, you put water in ice trays, and put the trays in a 20 degree or less freezer. It takes at least 4 hours for them to freeze. If you have spent the night, and all is well, with sun shining on your camper going down the road, I don't think you will have any problems.
Good luck and hope you have a safe journey.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 12-04-2011, 01:34 AM   #3
flyrotor's Avatar
You can also run your furnace on low during transit, it may use a bit of propane, but will keep everything inside from freezing.
I drove for years delivering nursery products all 4 seasons, our cargo trailers had suburban propane heaters, never had an issue. We kept the inside of the trailers above 60 degrees. Two propane tanks would last about a week even in subfreezing weather.
If you travel through tunnels, you may have to shut it off, and you should probably shut it off while re-fueling.
flyrotor is offline   Reply With Quote
Old 01-16-2012, 07:31 PM   #4
Steve Lange's Avatar
We have towed with our furnace on the way to Florida during Feb. from Kentucky. When we had our class A we traveled in the winter and used the furnace to keep the RV warm. They both have the same furnace so I see no difference. It would be interesring to hear other opions.
Steve and Jeannie Lange
Erlanger, Kentucky ( Northern Ky )
2010 Rockwood 8314BSS
2007 F250 4x4 Crew Cab 5.4
2010-8 trips/27 nights 2011-13 trips/35 nights
Steve Lange is offline   Reply With Quote
Old 01-16-2012, 07:59 PM   #5
Taranwanderer's Avatar
If you're worried about your traps and gray/black tanks, you could always pour some RV antifreeze in the traps in the AM when you get moving and some down in the tanks to start with. That, coupled with all the sloshing around, would likely keep things from freezing up.
2015 XLR Hyperlite 30HFS5 (mods being performed regularly)
2009 Salem LA 292fkds (gone)
Nights- ('12)23 ('13)23 ('14)15 ('15)31 ('16)27 ('17) 20
2016 Ford Fusion Titanium (gulping gas again, camping support vehicle)
2014 Harley Davidson FLHX (XLR cargo)
2011 Ram 2500 CC 4X4 CTD, B&W Companion (toy hauler hauler)
Taranwanderer is offline   Reply With Quote
Old 01-17-2012, 02:48 PM   #6
The boss and I are headed down to Las Vegas from Southern Alberta at the beginning of February. Woke up this morning and the temp was -28C (-19F). I believe if its still that cold in a couple of weeks, I will certainly be using the furnace in transit.... Hopefully we will meet Spring in Northern Idaho..
2011 31' RETS Sabre
2007 Dodge Ram 2500 HD
Lovin It
spurge1947 is offline   Reply With Quote
