Old 10-10-2019, 02:09 PM   #1
Winterizing
I have been under my cabinetry w/ a flashlight - my water heater has no bypass. It has 2 valves w/ some tag dangling off one of them saying its a different bypass system.
Of course I have no documentation on this system, nor does the online manual direct me to anything besides the standard bypass.
I expect an adventure in a couple weeks when I go to winterize. Anybody else have a WH w/ no bypass in the middle?
2020 Rockwood Mini Lite 2509s
2019 F-150 3.5 EB SCREW Max Tow - 1797 payload
Blue Ox SwayPro w/ 1000 lb bars
s1njin is offline   Reply With Quote
Old 10-10-2019, 02:24 PM   #2
Hatchdog's Avatar
Is there a water line running in between the two valves? If so, when you close the two valves the water heater will be bypassed and the water/anti-freeze will run into the connecting line. This is the way my Rockwood 2608 is plumbed, I donít have the third valve on the WH as some folks do.
2020 Rockwood Ultra-lite 2608BS TT
2011 F250 Lariat 6.2 gas 6 sp auto 3.73 rear 4X4 6.75í bed crew cab
Recurve R6 hitch
Hatchdog is offline   Reply With Quote
Old 10-10-2019, 02:58 PM   #3
Kasual Kamper
Maybe if you can post a pic of your setup, we will be in a better position to advise you.
Current: 2013 Flagstaff MicroLite 21DS
Past: 2000 Fleetwood Mallard 19N
TV: 2013 Nissan Pathfinder SL 4x4
JayArras is offline   Reply With Quote
Old 10-10-2019, 03:59 PM   #4
Site team note: Moved the 3 posts above to their own thread.
Iwritecode is offline   Reply With Quote
Old 10-10-2019, 11:10 PM   #5
There are a number of ways they've come up with to plumb the water heater bypass. I'm attaching a doc showing 5 or 6 of them; it may help you.
My Mini Lite has the standard 3 valves.
2011 Traverse LT, 3.6L, FWD
Old 10-11-2019, 05:09 AM   #6
whirledpeaz's Avatar
Our ultra lite is like this. To bypass just turn both valves to be inline with the pex piping. The tag on mine explains this on the back of it. The white braided line is the bypass line. I think they've just eliminated the third valve in the bypass line itself.
Name:	wh bypass.jpg
2020 Rockwood UltraLite 2608BS
2017 F250
whirledpeaz is offline   Reply With Quote
Old 10-11-2019, 07:42 AM   #7
This looks closer to what I have.
I should have snapped a picture - I brought the camper home late yesterday. To get to my bypass valves I have to pull my kitchen drawers out. I did have them all on the floor yesterday, but that was for another project. I'm using the slide lock bar they gave me as a sink support (seeing as how I'm reading many are falling out of the countertop). I was so happy w/ my idea about supporting the sink easily that I forgot to take the picture of the valves while I was under there.
*yes I bought another slide-out lock to replace the one I repurposed. A nice ratcheting one that makes it easier to use*
