Old 11-08-2014, 08:59 PM   #1
Dorey's Avatar
Winterizing
I purchased a 30 ft rockwood this summer and attempted to winterize today. I started with 2 gallons of antifreeze put into the fresh water holding tank. I turned on water pump and tried to get pink to come through the faucet. I never had enough pressure in the water system to get any antifreeze to come through. I called a friend that said add 2 more gallons, i did that and still never had enough pressure to have it come through the faucet. Any suggestions?
Dorey is offline   Reply With Quote
Old 11-08-2014, 09:04 PM   #2
caper's Avatar
Can you get access to the water pump? If you can remove the hose that comes from the fresh water tank. A a shower hose will fit onto the pump. You can then pump the pink antifreeze through the trailer. I would not put the antifreeze into the fresh water tank because it will be a pita to get all the taste out come spring.
I did mine this way and it only took 1 gal. to fill the plumbing and the second gal. i put down the drain pipes.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 11-08-2014, 09:10 PM   #3
RPAspey's Avatar
Ok..here's the scoop. You should never put the RV antifreeze in the fresh water tank. You will have a hard time getting the taste out of the tank.
There is a siphon kit that hooks to the intake side of the pump. The kit has a long hose that is used to siphon the antifreeze directly from the gallon jug. Works like a charm.
Drain the fresh water tank and flush it with fresh water. Might need to do this a bunch of times to get rid of the taste. Good luck.
2000 Cherokee 29BH with 6V batteries, LED lights & 400 watts of solar power, flipped axles and raised. 2007 Tundra 5.7L DC-LB with lots of mods. C-co, 8/158th AVN Maint.
RPAspey is offline   Reply With Quote
Old 11-08-2014, 09:29 PM   #4
asquared's Avatar
In addition to the above advice, make sure your water heater is bypassed and drained. Winterizing should only take about two gallons (with some of that leftover).
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 11-08-2014, 09:32 PM   #5
Save the anti-freeze that you drain out of the fresh water tank and use it in the p-traps of the sinks/shower.
2014 Rockwood 8280WS
2010 Tundra 5.7 Dbl Cab 4x4
ronb707 is offline   Reply With Quote
winter, winterize
