Old 09-27-2013, 07:08 PM   #1
canterburyshoe's Avatar
Winterizing 8289WS
This is the first winter with our 8289WS and I was looking to antifreeze it. It has the winterizer port on the outside. It says close the valve to the tank and open the valve to the inlet. I know where the hot water heater bypass valves are. I tried sucking the antifreeze in after closing the hot water heater bypass but nothing happened. I did not see anything else in with the water heater. Does anyone know where these other valves might be?
ID:	40356   Click image for larger version
2013 Rockwood 8289WS
2012 F350 crew cab 6.2 - 3.73
Reese 16K hitch
Days camping 2013 - 26
canterburyshoe is offline   Reply With Quote
Old 09-27-2013, 07:27 PM   #2
There should be a panel in the basement (same side as antifreeze inlet) that you remove which will expose the water pump and water lines. I have a rockwood 8280 and panel is attached with 5 screws. Once removed you will see all of the various water lines. One of them will have a black valve that you can turn which will allow you to siphon the rv antifreeze through the inlet.
2012 Ford F150 Ecoboost, max tow/payload
2014 Rockwood 8280WS
2002 Harley Heritage Softail
2006 Club Car Precedent golf cart
dirtman7 is offline   Reply With Quote
Old 09-27-2013, 11:21 PM   #3
Owner/Operator
RodeoGeorge's Avatar
It is the same on the 8289WS. There is a three way valve on the input line of the water pump. You'll need to get into that area anyway to drain the filter, if you haven't bypassed it.
RodeoGeorge
Mods: Central Vac, PI EMS-HW50C, 2025RV, (2) SCS225 Trojans, PD9260, Awning Remotes & LED Lights, Eliminators, External Water Filter,, Intellijacks
2008 RAM 3500 Cab&Chassis Hauler Bed, B&W Companion Hitch
All My Modifications are at this link:
http://www.forestriverforums.com/for...ons-36212.html
RodeoGeorge is offline   Reply With Quote
Old 09-28-2013, 06:47 AM   #4
Thanks, I will take a look. The manual tells you nothing but fill the fresh water tank.
Reese 16K hitch
Old 09-28-2013, 07:13 AM   #5
I found it, and that did the trick. Thanks for the help.
Reese 16K hitch
Old 10-01-2013, 10:58 AM   #6
5er_tom's Avatar
For winterizing the rig, I use compressed air. I open the drain vales and also drain the water heater. I then blow compressed air through the city water inlet. I open the faucets in the rig one by one and let the water spit out. Don't forget the shower and toilet.
After closing the drain valves, pour RV antifreeze down all the drains and into the toilet. I have found that this method also blows all the water out of the water filter.
I did this many times last year and had no issues. We use our rig all year long, so I end up winterizing it several times each winter.
Tom & Renée
Durham, NC
2015 Wildcat 295RSX
2012 Ford F-250, 4x4, 6.7 Liter Diesel
5er_tom is offline   Reply With Quote
Old 10-01-2013, 03:26 PM   #7
PhoneDude 8289's Avatar
What about the 12V water pump, could that freeze and cause damage? As far as I can tell blowing air through the city water inlet does not clear the the pump and the few feet of those lines.
PhoneDude 8289 is offline   Reply With Quote
Old 10-01-2013, 04:44 PM   #8
5er_tom's Avatar
Good point. I did not do anything about that, and never had problems. Perhaps I should blow some compressed air into the fresh water tank while running the water pump. That would clear the lines, yes?
Tom & Renée
Durham, NC
2015 Wildcat 295RSX
Old 10-13-2013, 08:26 PM   #9
jlshari's Avatar
do not forget about the out side shower
jlshari is offline   Reply With Quote
winter, winterize
