Old 11-20-2015, 02:25 PM   #11
To Oscarsmom2, I think you are right about the low water drain because there wasn't any water in the water heater when we finally got the anode out so that is helpful to know as well
dkkirkland is offline   Reply With Quote
Old 11-20-2015, 02:56 PM   #12
Capt. Mike's Avatar
Originally Posted by stantyszka View Post
Anyone put their anode rod back in for winterizing? Other solution to prevent critters from squeezing in there?
I leave the anode rod out all winter. I've never had any "critters"get into the water heater. It is COLD in there during the winter...no reason for them to get in the heater.
Mike and Yvonne
and Sophie, the little white dog
2017 Columbus 320RSC
2015 Chevy Silverado 2500HD Duramax 4X4
“It's not how old you are, it's how you are old.”Jules Renard
"It's not the years...it's the mileage." - Indiana Jones
Capt. Mike is online now   Reply With Quote
Old 11-20-2015, 08:07 PM   #13
buffalohunter's Avatar
All this just makes me not feel as bad as I normally do about living in California. Then again the lower cost of living out of CA would offset the cost of having a service tech do the job of winterizing the TT.
Happy Holidays to you all.
2012 Rockwood Windjammer 3008 W
2007 Tundra Reg Cab 4X4 SR5 5.7L
buffalohunter is offline   Reply With Quote
Old 11-21-2015, 09:53 AM   #14
You should try living in Washington DC suburbs, it's just about as expensive as living in CA plus having to winterize
Old 11-24-2015, 09:47 AM   #15
RusLwt001's Avatar
Originally Posted by dkkirkland View Post
We did end up using the antifreeze inlet, it just took a lot of searching to find the valve to allow the inlet to work. It ended up being behind the pump under the bathroom sink and was difficult to see. Once we used the valve, the antifreeze pumped great through the system. You are right that it will not pump from the city water inlet.
Which way should the valve be turned? I have a lever on the outside of my Windjammer 3025W marked "Winterize"; Do I still have to open or close the valve that feeds into the Water Purifier? I have removed the cartridge. I just can't figure out what to do with that valve. The only valve I see next to the pump appears to feed directly to the purifier. I am a little lost on this issue.
RusLwt001 is offline   Reply With Quote
Old 11-24-2015, 12:11 PM   #16
We pumped antifreeze through the water purifier (without the filter). We don't have a valve on the outside of the trailer to winterize, only an inlet for the antifreeze. The valve next to our pump (inside the trailer under the bathroom sink) allowed the outside inlet for winterizing to pump the antifreeze though the system. Without turning the valve, the outside inlet wouldn't suck antifreeze into the system at all. We also talked to dealer yesterday and they said to leave the anode rod out the water heater during the winter.
Old 11-24-2015, 02:04 PM   #17
RusLwt001's Avatar
Thank you. Going to finish this job tonight. Just another excuse to see the windjammer.
Russ
2016 Rockwood Windjammer 3025W
Diamond Package
2016 Ram 2500 6.4 Hemi 4x4
Old 11-25-2015, 03:17 AM   #18
Just a member
kandl's Avatar
Originally Posted by OscarsMom2 View Post
It's been my experience that if I open the low point drains for the water lines before removing the anode rod on the water tank that there is very little or no water in the water tank. The water must have somehow drained out through the low point drain.
Caution: If you open the low point drains without isolating the HWT (winterizing bypass), sludge/sediment from the HWT can and will be drawn into the RV's plumbing. It can thereafter be a PITA to clean it out.
Keith, Lori & the Wild Bunch
TT: 2011 Rockwood 8293RKSS
TV: 2009 Dodge Ram 1500 CC 4x4 (ya.. it's got a Hemi
kandl is offline   Reply With Quote
Old 11-25-2015, 03:32 AM   #19
Just a member
kandl's Avatar
Originally Posted by redcloud1 View Post
I go one step further with the water heater after a dealer showed me a water heater that had split from the water that didn't drain from the bottom of the tank. After putting the antifreeze in I switch the bypass back and run some info the water heater.
The bypass system is there to prevent antifreeze from getting into the HWT. I suspect the dealer with the split tank demo was spinning some yarn. The tank was likely left to freeze while partially full.
Old 11-25-2015, 03:43 AM   #20
Just a member
kandl's Avatar
Always. There are no critters of concern when we hit -30 and then some. Some suggest leaving the anode out to let the residual H2O evaporate so that the HWT doesn't get damaged when it freezes. Truth is, the residual water, once frozen, will not damage the tank.
3008w, drain, heater, water, water heater, windjammer, winter, winterize
