Looking at pics of your unit, the WH appears to be under the floor just outside the bathroom door. I suspect the two steps are able to be popped up to give you access behind the WH.
Alternatively, open the pass-thru just forward of the WH and look for a way to access the WH through the rear wall of the pass-thru. May need to unscrew a panel.
For something you need to access at least once per year, they never seem to make it simple.
2011 Traverse LT, 3.6L, FWD
