Old 09-07-2014, 10:43 AM   #1
Winterizing question for 2904SS
Purchased a new 2014 2904SS and have looked over the information on how to winterize. I have done this on three other trailers that I owned in the past. My question is the location of the valve to the fresh water tank and the valve to the pump. Do I get to them through the storage area? On my older trailers, these were easily located.
diesel901 is offline   Reply With Quote
Old 09-07-2014, 10:53 AM   #2
Ford Idaho's Avatar
From inside the TT look to where the water heater is located in the wall, now look for a panel that may have 2-4 screws.
If you have such a panel remove it, with luck you will see the back side of the WH and the valves.
Note their relationship to the water lines.
Old 09-07-2014, 11:02 AM   #3
Thanks Ford Idaho. I did see the panel with the screws that you mentioned. I just didn't want to start taking things apart if not needed. I thank you again for the help.
winter, winterize
