Old 11-05-2012, 11:51 AM   #1
Hoo Dad's Avatar
Winterizing with air
This may have already been posted, but just a friendly reminder....If you are not going to pump antifreeze through your system, but instead use air to blow out your water lines, be sure to remove and empty the sediment bowl (which will most likely be full of water) located on the suction side of your pump. Otherwise this may freeze and bust. I also disconnect and leave disconnected the suction and discharge lines and tilt the pump sideways to empty all water. Just running your pump empty will not empty the sediment bowl of water.
2011 Rockwood 8285 WS
2011 GMC 3500 HD 4X4, 6.0, 4.10, SRW
Hoo Dad is offline   Reply With Quote
Old 11-05-2012, 12:09 PM   #2
TURBS's Avatar
good reminder !
I flush with air and fill with anitfreeze . overboard ? maybe ! protected ? YES !!!!!!!!!!!!!
TURBS
Old 11-05-2012, 12:42 PM   #3
RalphieAdie's Avatar
Thanks for the tip.
Ralph & Adrienne
2016 Flagstaff 8528CKWSA
2012 GMC Sierra 2500HD 6.0L
RalphieAdie is offline   Reply With Quote
Old 11-05-2012, 02:09 PM   #4
JoeyO's Avatar
Send a message via Yahoo to JoeyO
I'm stumped on what this is refering to - where by the pump is this bowl located, or what does it look like? Anyone take a picture of this?
OTeam
2018 Genesis G80
2010 370z Convertible 6 Stick
2011 Expedition 5.4L 4x4 Limited
2018 Highland Ridge 275 Light
Semper Fi
JoeyO is offline   Reply With Quote
Old 11-05-2012, 03:19 PM   #5
Hoo Dad's Avatar
This is not exactly what I have but close enough. The bowl is just to the right of the pump.
Old 11-05-2012, 05:37 PM   #6
GlacierGus's Avatar
Thanks Hoo Dad. Good advice.
2013 Rockwood Mini Lite 2109S
2006 Dodge Durango Hemi 5.7
Equal-i-zer WDH
GlacierGus is offline   Reply With Quote
Old 11-06-2012, 06:06 AM   #7
JoeyO's Avatar
That clear little bowl with the grey screen in it? Wow! I would never had thought to empty that! Thanks Hoo Dad for taking the time to post that picture!!! Overlooking something so small could cause a lot of BIG headaches!
OTeam
2018 Genesis G80
Semper Fi
Old 11-06-2012, 07:13 AM   #8
rattleNsmoke's Avatar
Using compressed air and pink stuff is the way to go.
Mike
rattleNsmoke is offline   Reply With Quote
Old 11-06-2012, 07:26 AM   #9
JeffnTam's Avatar
X2, compressed air and anti freeze. Cost coupe $ but protected
TV: 2006 Chevy Silverado Duramax w/ superglide hitch. And with a bunch of other goodies.
36' FR Sandpiper 5th wheel
JeffnTam is offline   Reply With Quote
Old 11-06-2012, 07:38 AM   #10
jriddering's Avatar
Used compressed air on Sunday and went back and used pink anti freeze last night just in case. Thanks
Jim and Carol
2012 Crusader 290RLT
2010 Ford F-250 King Cab Diesel
Harley Davidson Edition
jriddering is offline   Reply With Quote
