Won't pump antifreeze from outside inlet
Need some help. Tried using the exterior inlet today to winterize my 8319SS. I bypassed the water heater, shut off valve to fresh water tank, but antifreeze would not pump from jug. Seems simply enough, not sure why it didn't work.
After several tries, I disconnected the fresh water inlet to pump, connected a hose with other end in the jug and it worked like a champ.
Any ideas? Thanks
