Old 01-07-2014, 04:21 PM   #21
Always Learning
Originally Posted by OldCoot View Post
Thanks, need one that is watertight and lockable to mount on back bumper.
Different stroke for different folks. I'd honestly love to have one of the power winders for my cord. I just really can't imagine spending that kind of money for it!
Old 01-08-2014, 01:28 PM   #22
Helmsey's Avatar
Sounds like you might have a new project on your hands
2015 Chevy 3500HD
2013 Sandpiper 365SAQ
Helmsey is offline   Reply With Quote
Old 01-08-2014, 02:16 PM   #23
kerrlakelover's Avatar
You know OC, you might have something there. Since we can't put much else on the back bumper, I'll bet us creative FRFers could customize the Mor-ryde reel to be fairly water proof and mount it on the back bumper. (put a bottom on it, seal the seems, and fabricate a fairly waterproof and lockable lid for it) As with most things we "lock or secure" in our trucks or outside the RV, it will only prevent the honest folks from walking off with it. Since the cords lay out in the weather when in use anyway, what difference does it make if it gets a bit damp while being stored on the reel on the back bumper. That way it doesn't take up other valuable storage space and will take a fraction of weight off the pin box. Just a thought...and "I'm not a very smart man".
North Carolina born and bred
2010 Sandpiper 345RET
2011 2500 Duramax Silverado
2001 Centurion Elite Bowrider direct drive
"Old water skier"
Jesus Christ my Saviour
kerrlakelover is offline   Reply With Quote
Old 01-08-2014, 03:42 PM   #24
Have a good friend with a $$$ (50A) Motor Home who uses a (30A) supply cord (99%) of the time. Youroo!!
Old 01-08-2014, 05:51 PM   #25
I've got the cargo bay reel that came with our Silverback and find that it makes rolling up that heavy cord a lot easier. However I don't know how stiff the cord would get at temps around 40 F. The footprint of the reel is quite small approx. 8 x 14 inches and I don't think I would want to be without it!
Of all the things I've lost in my life the thing I miss the most is my mind!
prairiecamper is offline   Reply With Quote
Old 01-09-2014, 10:20 PM   #26
Denver, CO
garbonz's Avatar
A 50 amp power cord is the heavyist thing I have to lift, manipulate and lift in and out of the storage area. I'm all for getting a cord reel. Shoreline makes an electric one that is only 20$ more than the Mor Ryde manual one.
2017 Fuse 23T
Old 01-09-2014, 10:38 PM   #27
B47
We have a friend who has a 2012 Monaco Diplomat MH ( a beautiful machine). His power cord is stowed on a electrically powered reel in a compartment on the left rear side of the MH. He opens the door and pushes a button and the cord comes out or in. Nice.
Old 01-10-2014, 12:57 AM   #28
Broke and happy
bobfa's Avatar
I picked up one of these at Home Depot. 36" Velcro strap and zinc plated hook set, rated for 300 lbs. Will keep the cord together and maybe hang it off somewhere in the front storage area.
Husky 300 lb. 36 in. Zinc-Plated Steel Hang-All-18390 at The Home Depot
bobfa is offline   Reply With Quote
Old 01-10-2014, 05:51 AM   #29
"On the road again"
rjshiflet's Avatar
I use a heavy duty plastic storage box like this and also use it to store my surge protector and the chain & padlock that I use to protect the surge protector from walking off. Then, it slides in the side compartment with my two smaller plastic bins on top (those two contain my fresh water hose and cable/satellite coaxial wires).
JTT Storage Trunk, Model# 2820-20P | Tool Boxes| Northern Tool + Equipment
Robert & Estha Shiflet
Georgetown XL 378TS
Jeep Gladiator Willys Tow Vehicle
rjshiflet is offline   Reply With Quote
Old 01-10-2014, 08:22 AM   #30
AquaMan's Avatar
That's what I use also. When I put in my EMS I used a section of 6 gauge high strand appliance wire that was extremely flexible. Thought about making an extension cord from it, but it was $5.xx a foot.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
Old 01-10-2014, 08:31 AM   #31
Always Learning
You've got a nice looking box.
I like that. Seems like it would give me a bit more room than the 5 gallon bucket that I'm using now.
Old 01-10-2014, 08:46 AM   #32
PhoneDude 8289's Avatar
My 50 amp cord is stored in a 5 gal bucket and stored between the slides at the rear of the RV. This reduces some weight from the pin up front and doesn't take up any storage space
Joe & Beverly
2014 Ram 2500 CTD, CC, SB
2014 8289WS lifted
PhoneDude 8289 is offline   Reply With Quote
Old 01-10-2014, 09:49 AM   #33
Old Enough to Know Better
gasman6674's Avatar
Anyone know the minimum bend radius for the 50 amp cord? Its a #6-2 or 6-3 isn't it?
Jim & Debbie England
Do you have Gas? 2015 F350 6.2L CCLB DRW 4.30 axle.
2020 Keystone Cougar 364BHL ,Gone 2012 Yellowstone Ridgeline 34RLT Fifth Wheel
gasman6674 is offline   Reply With Quote
Old 01-10-2014, 10:07 AM   #34
skipperW's Avatar
This is what I did with mine....mounted a 5 gallon bucket inside a muck bucket. I drilled a hole in the side near the bottom for the RV end to come out and coiled the rest of the cord around the bucket. I only have to uncoil the amount needed and the rest stays in the muck bucket. The rope handles on the muck bucket make it easy to handle and I store all my adapters in the lidded 5 gallon bucket. I did drill some holes in the bottom to let any rain water drain.
tn | Flickr - Photo Sharing!
skipperW is offline   Reply With Quote
Old 01-10-2014, 11:38 AM   #35
AquaMan's Avatar
I'm not sure of the bend radius, but I believe its a #6-4 wire. 2-hot 1- neutral 1-ground
Old 01-10-2014, 02:41 PM   #36
Campfire Master
I use this reel. You can buy it without the air hose. Mounted the base on the floor of the basement. It holds 30 feet of 50 amp with ease.
Harbor Freight
John
AVid is offline   Reply With Quote
Old 01-10-2014, 02:53 PM   #37
gasman6674's Avatar
I was thinking about that myself, I wonder if it would work for the stiff --- 50 amp cord
I may invest $20 in this project cheaper than $200
Old 01-10-2014, 03:02 PM   #38
Campfire Master
It works fine with a 50 amp cord. I hook the male end under one of the u shaped pieces. I then feed the cord with one hand and crank with the other. I have even kept a rag in my feed hand to wipe the snow off, so it does work fine in the cold too. I would post a picture of it installed, but I would have to climb over a 5 foot snow drift to get to it.
John
Old 01-10-2014, 04:18 PM   #39
gasman6674's Avatar
Thanks AVid I missed 50 amp in your original post
DOH
Old 01-10-2014, 04:43 PM   #40
Denver, CO
garbonz's Avatar
Awesome idea.
2017 Fuse 23T
50 amp, power
