06-08-2017, 07:09 AM
Rockwood 2902ss
X-chocks for 2902ss
Looking to buy x-chocks to stop back and forth movement in my rockwood 2902ss. But I'm afraid they might not work because my tires are so close together. Has anyone had luck with these with a small clearance between tires.
06-08-2017, 08:10 AM
Use them on a 2504s and they work great.
06-08-2017, 10:05 AM
Use them on the 2703WS and they are fine.
Marty
2016 Rockwood 2703WS Sapphire
2016 F250 SD 6.2L
06-08-2017, 10:11 AM
your tires can't be any closer than ours on the Micro Lite 25KS, ...... and they work great .....
06-08-2017, 10:42 AM
Rockwood 2902ss
Mine look about the same distance thanx for pic
06-08-2017, 12:12 PM
I am using them on my 2902!👍
06-08-2017, 12:27 PM
It's 2-1/2" between the tires on the 25KS/2503S; I'd say it could go down to 2" and they'd still fit.
2011 Traverse LT, 3.6L, FWD
06-08-2017, 12:52 PM
They will fit in a space as small as 1 3/8" between the tires. That info is listed on the BAL site.
06-08-2017, 10:19 PM
2017 Windjammer 3029w
Fits my Windjammer 3029 just fine. They just crank down to close to the minimum but work fine.
06-09-2017, 12:45 AM
I use them on mines, I bought them on Amazon they were a little cheaper than Camping World, they work great, along with my tires chocks.
2018 Dodge Ram 3500 6.7L CTD
2019 Jayco Eagle 321RSTS
Retired Army MSG.
06-09-2017, 10:03 AM
Resist the temptation to over tighten them...they can damage tires
06-09-2017, 10:16 AM
I'll disagree on this.
The pressure you can exert by tightening an x-chock is nowhere near the pressure which the static load of the camper itself puts on a tire.
I have tightened mine tight for years with no ill effects.
Days Camped ☼ '19=118 ☼ '20=116 ☼ '21=123 ☼ '22=134 ☼ '23=118☼ '24=86
06-09-2017, 11:34 AM
No problem with opinions...
My opinion is that the edges of the X chicks are pretty sharp if you dig them into the tires. All you need is enough pressure to stop the wheel from rolling and you don't have to crank them down to 1,000,000 pounds. Ymmv
06-09-2017, 07:23 PM
I have used them since 2014 with my 8280ws. Have not had any experiences with them damaging tires. One suggestion is to tie a colored ribbon on the handle. To remind you they are there.
06-09-2017, 07:40 PM
I've got them on my "leaving camp" checklist.
06-09-2017, 08:04 PM
Disagree with you also, the edges are not sharp and even if they were, you can file them off or put a pc of hose on them, but the pressure is concentrated over 22.5 sq inches on each tire. (2.5" x 9") There is no way you can hurt the tire before breaking either the ratchet or the chock itself.
06-09-2017, 08:05 PM
that is the very reason for the orange duct tape, .... I wrapped the handles in the brown pipe insulation, because I like the cushioned grips and then added the orange tape as a visual reminder that the chocks are there and need to be removed before moving, ....
06-09-2017, 08:09 PM
If you put them on tight enough, you can't move the trailer. LOL
06-12-2017, 07:35 AM
X chocks are great!
2007 Rockwood 8318ss
2018 Rockwood 8324bs (on order)
Camping in Northern Michigan!
