Old 07-23-2016, 10:15 PM   #1
Yamaha EF2400i surges
I have a Yamaha EF2400i. it supplies power to rig great but it also surges as it runs which is quit annoying. with nothing plugged in it runs smooth and with high power draw it is also smooth. when it's just inverter and maybe television its RPM jumps all over. Has anyone else had this problem and do you know a solution. I have already had carb off and cleaned what I could and ran a can of Sea Foam through it.
thunderstruck is offline   Reply With Quote
Old 07-24-2016, 07:07 AM   #2
Carb dirty or air filter dirty or air leak between carb and engine
2016 Flagstaff 27VRL with overloaded tires from factory
2015 Chevy Silverado
Paul GA is offline   Reply With Quote
Old 07-24-2016, 07:51 AM   #3
SeaDog's Avatar
Try some Seafoam in the fuel. It cured the surging on my Class A Onan. I only run clean (non-ethanal) fuel in my Yamaha's to hopefully eliminate problems.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
AF&AM of Idaho
Old 08-05-2016, 08:44 PM   #4
Jhochst's Avatar
Seafoam works great. Follow instructions and let run for a few hours. I use sea foam treated premium gas now
Jhochst is offline   Reply With Quote
