Old 05-16-2015, 06:54 PM   #1
07 Surveyor Soft Floor Replacement Advice
Hello
My girlfriend and I found a good deal on a 2007 surveyor m291. Everything looks good except the floor. There is a 2 foot long soft spot in the floor. I was thinking of fixing it by cutting the floor open and using 1/4 or 1/2 inch pretreated plywood. Any advice? What should I expect? I've not worked on a camper before. I have some handy skills tho. The dealer said cutting the soft spot out would be easier then dropping the tanks and going from below. I looked at the roof, looks good. I'm 250lbs will it support my weight to walk on? Is there some type of sealer I can paint on the roof? I just want to make sure it water tight.
woodya is offline   Reply With Quote
Old 05-16-2015, 07:13 PM   #2
That good price ???? is because of that floor and it better be a VERY good price. To properly fix, the entire floor must be replaced and is a VERY expensive job. The floor is a "laminated" floor of foam sandwiched between two very thin pieces of plywood and the whole floor is one piece front to back, side to side. Cutting into it to repair is NOT advised by Forest River. That dealer should know better than to advise you of that. He's trying to move that RV out of his lot. Unless of course it's a "REALLY GOOD PRICE". Search this forum on "soft floors" and you will find a few ways owners have "fixed" this problem with some good results. Some ideas are easier than others and you need to decide if it's worth your time and effort to fix. This problem does not get better, only worse.
You also don't know if this situation was only the flooring issue or an even worse situation caused by water intrusion somewhere that may or may not have been fixed.
Spend more time researching this issue so you know what you are getting into.
Just my opinion on reading up on this to try to fix my soft floor issue.
2002 GMC Sierra 2500HD Duramax
2008 Rockwood Sig Ultra Lite 8315SS
Livin the Life is offline   Reply With Quote
Old 05-16-2015, 07:28 PM   #3
I personally stay away from dealers at least here in jersey. I got a great condition 2007 roo 21ss for half yes half what the dealer wanted on one with water damage on the bunk ends. I say keep looking
wraenking is offline   Reply With Quote
Old 05-16-2015, 07:31 PM   #4
Send a message via AIM to NoviBill
I had a similar issue with a Trail-lite, my first advice matches Livin the Life - RUN!
If you want a guess as to what a repair would entail take a look here: https://www.flickr.com/photos/cdrdwd...57627084950665
The floor is an integral part of the entire camper structure and needs to be done with care. Also you will need to root cause the problem, if it's water you will need to look for mold and remove it.
Bill & Renee from Novi, Michigan
2006 Lexington 255DS
http://anunbalancedbalance.blogspot.com/
NoviBill is offline   Reply With Quote
Old 05-16-2015, 08:21 PM   #5
They want $5000 for it. I see them selling for 9k. Is there a manual or schematic available? So I can get an idea of what needs to be done properly.
Old 05-16-2015, 08:37 PM   #6
vinmaker's Avatar
I agree. A soft floor usually totals a trailer. the cost to fix properly costs more than the unit. The seller most likely got paid ACV for the unit and then bought it for about $2,000 salvage price then put it up for sale to hopefully get more than the $2,000 they paid.
You bought it and can easily fix it from above if you do not care too much about the tile matching. Most people cut out the bad wood and replace with new wood. Then use stick on tiles to re-tile the floor. It will function as a floor.
Good luck.
Vin.
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 1000#
Old 05-16-2015, 09:57 PM   #7
Yes, you can make cosmetic "fixes" but it would not be done properly. NoviBill is correct that the floor is an integral part of the entire camper structure. It cannot be taken up in a piecemeal fashion and repaired as in a home flooring structure. My local dealer, nor any dealer for that fact, has the equipment to properly fix the soft floor issue. Any soft floor issue, under warranty, is sent back to the factory and taken apart and the whole floor is removed and a new whole floor is put in. They have the equipment to do this and it is cheaper for them to do this, under warranty, than to, of course, replace the whole unit. To do this on your own, without the benefit of warranty, would require you paying for getting your unit to the factory, parts and labor for removing the old floor, cost of the new floor, plus other parts needed, labor for installing the new floor and putting the whole thing back together. Now it can be done this way properly as you say. A few thousand dollars later with a new floor and you still don't know the actual cause and maybe it was a water leak somewhere and then your back in the same boat. Not a job for a do it yourself-er.
Except........as I said above, there are other older discussions on this forum where people have welded bracing underneath the frame and or put down thin, (3/8 in if I remember correctly), laminate flooring to spread the walking load and found some success in their cases. You would have to judge for yourself if that would help in your situation. I will look for these older discussions and post when I find them to help you decide. I don't mean to run on but I wish I heard of this forum BEFORE I made my purchase as there is a treasure trove of sad/bad luck stories as well as great stories about the RV life.
Old 05-16-2015, 10:07 PM   #8
Here are a few discussions on the subject, give them a look and there are many more out there with pictures as well.
sagging floor
ultra lite soft floor
New (to me) 2010 18BHXLLTD- soft floor
Repairs to soft floors
Floor replacement
Old 05-17-2015, 12:12 AM   #9
bikendan's Avatar
No
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 05-17-2015, 03:34 PM   #10
Soft floor replacement
Hello i have a 2000 Forest River Flagstaff with the same foam "waferboard" floor construction and im a larger guy so the floor started getting soft and i successfully repaired the floor 4 years ago using 1/2 inch Birch Plywood with the plywood glued down directly on top of existing floor lengthwise front to back of trailer glued down with PL Premium (Birch plywood is lighter and is sturdier with more layers) make sure all edges are tight fit and make seams on crossmembers away from main traffic spots and i removed and re-installed a new ceramic RV toilet on top of the plywood and had to add a new rubber seal. I then glued down some Laminate flooring again lengthwise front to back and glued down with Pl Premium with all edges tight as possible. I then had to trim the bottom edge of the bathroom door and bottom of drawers under the dinette as well as straighten the aluminum trim by the outside door and re-install. Then i added new wall trim on top of the floor all around the edges where possible. This floor is now quite sturdy and im sure will last
simonsays is offline   Reply With Quote
replacement, surveyor
