Forest River Forums
Sunline User Photos
Old 10-02-2011, 08:39 PM   #1
07 sv291 winterizing help
Hey guys I am about to get my TT ready for winter. I can not find the hose to pull the antifreeze into the lines/ Can anyone with one of these help me out and point me to where i should look. Or how to do it if there is no suction hose near pump. Thanks
campfun is online now   Reply With Quote
Old 10-02-2011, 09:29 PM   #2
Bill_C's Avatar
My trailer came with a clear hose and connector in a kitchen drawer. You have to disconnect the inlet side of the water pump, screw on the adapter hose and you are ready to suck the RV antifreeze out of a jug and through your trailer lines when you turn on the pump. Don't forget your outside shower!
DRINK COFFEE--do stupid things faster and with more energy !
Bill_C is offline   Reply With Quote
Old 10-02-2011, 09:31 PM   #3
Moderator
Well, I can't tell you because I don't have one. While you may know what an SV291 is, many of us don't. It is a Flagstaff, Rockwood, Work and Play, Shasta? Sorry, we can't keep up with them all, Please when asking questions, put in more info than you think is needed. It will help all of get you a faster answer. Also, once your trailer is a few years old, it is very difficult to find info with just a model number alone. Please don't take any offense, just trying to get you some help.
Windrider,
Too many toys, not enough time.
2001 F150 SuperCrew
2002 Jeep Wrangler
1978 Cessna 152
2000 Honda 750 Nighthawk
2008 Work and Play 18LT
windrider is offline   Reply With Quote
Old 10-02-2011, 11:25 PM   #4
too fast turbo sled
f1100turbo's Avatar
You may not have one. Go to any rv dealer they will set you up with a kit to do it for less than 20 bones.
2005 silverado 2500hd pro ride 5th
2011 palomino sabre 32 bhok-6
2012 arctic cat f1100 turbo limited edition sno-pro
Ron and Amy Benhart
2012 nights camped (5)
f1100turbo is offline   Reply With Quote
Old 10-03-2011, 07:42 AM   #5
Lou Amadio
herk7769's Avatar
Home stores have rolls of clear vinyl tubing of the correct diameter.
I got a plastic fitting (female NPT -> hose barb) that fits the water pump's inlet. Stick the six foot hose into the gallon jug on the ground outside the camper and suck away.
Remember: (IMPORTANT!)
1) REMOVE YOUR WATER FILTER AND REPLACE THE PLASTIC FILTER HOLDER or you will have a mess.
2) BYPASS your water heater! (drain and clean separately)
3) Remove the water pump fuse next to the water pump
4) Turn on the red switch water pump switch on your micro panel.
5) when you are ready to run the pump put the fuse in the holder.
6) when it shuts off (and it should or you have a leak somewhere) go inside and turn on your faucets one at a time until you see red RV antifreeze; then close them.
7) Flush the toilet until you see red in the bowl
8) Don't forget to flush out the Turbo Flush if you have one
9) Don't forget to flush out the outside shower if you have one
10) You must also add antifreeze to the city water connection or blow it out with compressed air. Failure to do this will fail your city water check valve and could freeze the trapped water in the line from the city water valve to the plumbing T fitting.
Lou and Laura Amadio and Bella the German Short Hair Pointer
2010 Flagstaff 8526RLWS 5th Wheel Pullrite Hitch
(2009: 28) (2010: 74) (2011: 93) (2012: 7)
herk7769 is offline   Reply With Quote
Old 10-04-2011, 08:41 PM   #6
gregm59's Avatar
I have a 2007 SV291. It has a winterizing kit installed. The winterizing kit is inside the pantry, under the pantry drawers. If you take the drawers out, you should be able to see if you have it. If you don't, you'll have to follow everyone's advice to install one.
2007 Surveyor SV291
Equil-I-zer hitch
2005 Durango Hemi
gregm59 is offline   Reply With Quote
Old 10-06-2011, 02:03 PM   #7
Triathletedave's Avatar
Wink Check the thread.
It's posted on the Surveyor forum thread, so I would assume that it's a Surveyor.
Triathletedave is offline   Reply With Quote
Old 10-06-2011, 02:57 PM   #8
too fast turbo sled
f1100turbo's Avatar
In the faq there is a post on winterizing
Ron and Amy Benhart
Old 10-12-2011, 09:06 PM   #9
retiredcgrider's Avatar
Winterizing
I love the way the manual tells you step by step how to do nothing!
George MacGillis USCG ret.
2006 FR Cardinal 29RKLE
2011 Dodge Ram 3500 Dully
2011 Can Am Spyder RT-S
retiredcgrider is offline   Reply With Quote
Old 10-26-2011, 12:38 PM   #10
bamasurveyor's Avatar
Just remove the lower panel under the pantry door. It is much easier than taking the drawers out and standing on your head to reach the Bypass valve.
Living Here in Alabama, I haven't used Antifreeze for the last four years. I just blow the lines out very good(including outdoor shower), leave faucets open, and I'm good to 15 degrees F. I just put some AF in toilet and traps.
John
Ted
bamasurveyor is offline   Reply With Quote
Close [X]
