Old 10-22-2017, 01:15 AM   #1
2017 226 water pump
Any one know where the water pump lives in a 2017 surveyor 226?
Sfry is offline   Reply With Quote
Old 10-22-2017, 06:21 AM   #2
NH Maple Maker
russhd1997's Avatar
Turn the pump on and follow the sound. I found the one in my Vibe that way. Mine is under the bathroom sink. You may have to take off a panel to access it once you find it's location.
If you are trying to find it so that you can winterize you can buy a manual pump that will pump the anti freeze through the city water connection. I bought one and it works great. It takes two people to winterize that way, one to turn faucets and one to pump the pump but you don't have to take anything apart.
Russ
2014 V Cross VIBE 822VRBS
2017 Silverado 1500 crew cab 4x4
russhd1997 is offline   Reply With Quote
Old 10-22-2017, 03:30 PM   #3
Thanks. The pump sounds like an option
Old 10-22-2017, 03:58 PM   #4
NH Maple Maker
russhd1997's Avatar
Here's a pic of the pump that I got. $25.00 at a local dealer.
http://www.forestriverforums.com/for...1&d=1508702195
Russ
Old 10-22-2017, 06:28 PM   #5
I have something similar and it works like a charm....
2018 267 RBSS
2009 Expedition Eddie Bauer 5.4L
18267RBSS is offline   Reply With Quote
Old 10-22-2017, 07:06 PM   #6
Does it get antifreeze into the water pump also?
Old 10-22-2017, 07:21 PM   #7
NH Maple Maker
russhd1997's Avatar
Yes it does. The water that is in the pump itself will mix with the anti freeze that is in the pipes.
Russ
Old 10-28-2017, 06:06 PM   #8
Love the hand pump but still looking for the coach pump to clean the strainer
Old 10-29-2017, 09:45 AM   #9
NH Maple Maker
russhd1997's Avatar
Looks like you already winterized but do this. Open one of the faucets and turn on the pump. Follow the sound until you get an idea of where it's located. Check under beds, cabinets and sinks etc. As long as you don't run the pump too long with no water in it you won't hurt it. The pipes don't need to have anti freeze in them so any that gets pumped out won't need to be replaced.
Russ
Old 01-16-2018, 02:54 PM   #10
Bowmanville SVT255S's Avatar
Under the bathroom sink
2015 Ram Crew Hemi
2005 Surveyor SVT 255RS
Bowmanville SVT255S is offline   Reply With Quote
pump, water, water pump
