Old 01-18-2015, 09:53 PM   #1
216BXHL Not Hot Water
I have a 2015 Surveyor. The hot water heater works, but we only get luke warm water, anytime. I've looked for a balancing valve, maybe I'll have to pull one if the access panels to fund it, since nothing's jumping out at me? Any ideas? Thanks for the help.
rbhmds is offline   Reply With Quote
Old 01-18-2015, 09:56 PM   #2
wmtire's Avatar
You're on the right track. Look at where the water heater is on the outside, then figure out how to get to the backside of the water heater from inside the RV. You may have to remove a fake cabinet door, drawer, etc to access the bypass valves on the rear of it. You probably have either an incorrect set bypass valve (not fully closed) or a bad one. This is common
If you have the 3 valve system, you will need the handles turned like in the pic for normal use to keep the cold water from mixing in with the hot water:
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 01-18-2015, 10:04 PM   #3
Thanks so much, we'll pull the panel in the AM and give it a look see. Thanks again for the quick response.
Old 01-19-2015, 11:33 AM   #4
electroblast's Avatar
Make sure your external showers valve are shut off, or even your valve on the main shower, sometime you might just shut the shower using the valve on the shower head, as for result cold water will return in the hot lines.
Good luck.
Jean & Lucille
2014 Crusader 325RES Touring Edition
2011 Silverado Duramax 6.6L W/Allison
electroblast is offline   Reply With Quote
Old 01-19-2015, 01:00 PM   #5
luke warm water
There should be a panel between the hopper and the back side of your water heater.
Ken Y is online now   Reply With Quote
Old 01-19-2015, 01:07 PM   #6
On my 2013 Surveyor there is a panel between the hopper and the back side of the water heater. Four screws, #1phillips tip is all you need to get access to it.
Old 04-16-2015, 07:33 AM   #7
I'm actually going to work on this Sunday, time to get it ready to roll.
Old 04-16-2015, 03:01 PM   #8
Are you running propane and electric?
2017 Keystone Cougar 28RDB
Buck1032 is offline   Reply With Quote
Old 04-16-2015, 04:03 PM   #9
This is a "propane only" system.
Old 04-18-2015, 07:15 PM   #10
I see. My apologies for my lack of knowledge.
hot water, water
