Old 09-30-2018, 01:54 AM   #1
AC Kaput
We got to the Florida Frog Rally, got set up and discovered that the A/C wasn't cooling. Fan works but the air coming out is ambient air temp. One morning I kept raising the thermostat up until the fan cut off at 81. Dropped the set point to 79. The unit came on and never shut off. Midday it was cooler outside than in.
It worked fine the last time we went out (June). We run it set at 85 on shore power at home to keep humidity down. Last time I was was outside for sufficient time I noticed it cycling approximately normal.
Reckon I'll be calling Dometic come Monday. It should be under warranty. The TT is only 6 months old.
mawilson is offline   Reply With Quote
Old 10-01-2018, 09:04 AM   #2
SeaDog's Avatar
More then likely it has lost its charge there is no cost effective what to recharge or chase leaks in these units and are normally changed out. Go it is under warranty.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 10-03-2018, 03:02 PM   #3
Coolharts's Avatar
You will have to take it to a Dometic Authorized Repair facility.
My dealer suggested that I replace my failing Dometic (out of warranty by a few months) with a Coleman. Dometics are problematic.
2017 Surveyor 33RETS with Residential Refrigerator and Inverter
2005 Ford Excursion 6.0L 2WD
Nights Camped 2016 27, 2017 29
2018 25 2019 21
Coolharts is offline   Reply With Quote
