Old 08-12-2014, 04:37 PM   #1
AC keeps tripping breaker
My husband is working out of town and living in our 2009 surveyor sport. Last week he used the AC just fine, now whenever he turns it on it trips the breaker. Any ideas as to why it's doing this? We are new to owning a travel trailer so I appreciate any help you have.
Rhonda1521 is offline   Reply With Quote
Old 08-12-2014, 04:49 PM   #2
fonzie's Avatar
If it is a 30 amp supply, he might be overloading the circuit: when using AC make sure water heater is on propane only.
Fonzie
Old 08-12-2014, 04:54 PM   #3
B and B's Avatar
Also make sure things like Coffee Makers, toasters and fry pans are not used as they draw almost half the available power.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 08-12-2014, 08:52 PM   #4
Thanks guys. Turning off the hot water heater helped
Old 09-24-2014, 08:28 PM   #5
I replaced the anode rod in my hot water tank and it stopped my breaker tripping
crazycampers is offline   Reply With Quote
Old 09-24-2014, 08:39 PM   #6
wmtire's Avatar
Uh-Oh, that doesn't sound good. One possible reason it helped, is you may have accidently burned up the element and/or hi-limit t-stat during the process of changing the anode.
Did you make absolutely sure to turn off the electric heating element switch on the Suburban, before you drained the water heater? If not, then most likely you burned something out, thus the element is not working.....and not overloading a 30 amp breaker with the A/C on since the element would now not be drawing ANY amps.
Suburban's electric switch and much more
Are you certain that the electric heating element side of the Suburban water heater is functional.....or are you only running it on propane?
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
breaker
