Old 08-29-2015, 07:48 PM   #1
Happy Camper
Adding second A/C
My 2015 - 321BHTS air conditioner holds it's own in our Alabama heat but when the grand kids come, it takes a beating. Has anyone got advice concerning do-or-don't as to adding a #2 unit.
The 50amp service came standard and I was told the wiring is in place for the second unit. I assume it will mount where the roof vent is in the rear bunk room. Help, thoughts, suggestions, or advice appreciated.
I have avoided contacting the Calera CW facitity where I purchased the unit due to many service problems.
Johntgif is offline   Reply With Quote
Old 08-29-2015, 07:57 PM   #2
R3Jones's Avatar
Go for it! Especially if it's pre-wired, you've got the hard part done. Pplmotorhomes.com has them for $400! You won't regret it.
-R.Jones
Nitro 31FQSL
RJones
2016 Nitro 31FQSL
2017 2500 Denali Duramax
R3Jones is offline   Reply With Quote
Old 08-31-2015, 09:11 PM   #3
armyfa78's Avatar
My 2015 321bhts already had the 2nd AC on it when I purchased at the dealer. I felt lucky cause I have not found another 321bhts that has the 2nd AC. It's mounted over the front bedroom which I'm pretty sure is where your wiring is. And let me tell you, it blows cold and hard. Wouldn't trade it for the world as we live in Louisiana .Click image for larger version
Name:	ImageUploadedByForest River Forums1441073459.351013.jpg
armyfa78 is offline   Reply With Quote
Old 08-31-2015, 09:15 PM   #4
armyfa78's Avatar
Any other stories/comments to share . Would love to hear them
Old 08-31-2015, 09:26 PM   #5
TURBS's Avatar
I just installed a second a/c on my sabre.
Now with that said my friend and I was able to set a/c of the tailgate of my truck to the roof.
My camper was only 30 amp so it was not prewired so I ran a new service for the second a/c.
My camper also had the blocking already installed for an a/c.
Your 50 amp should be prewired and have the blocking.
Just pull down the inner vent trim ring and you should see the blocking for and aft.
If you feel around you should also see find the wiring.
I went with the non ducted unit vs the ducted model and the install was straight forward and easy.
Tonight I had both a/c ' s running and it cooled down VERY quickly!
Here's my install thread.
Buy a dometic non ducted Brisk air II and the non ducted ceiling kit.
Only thing you'll probably need special is a inch lb torque wrench.
http://www.forestriverforums.com/for...ad.php?t=90283
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "24 nights"
Old 08-31-2015, 09:35 PM   #6
Happy Camper
Thanks for the informative replys.
I will research those options.
Old 08-31-2015, 10:21 PM   #7
Phat Phrog Stunt Crew
elind's Avatar
My Wildcat was pre-wired for a second A/C that only took an hour to install the unit over the bedroom vent. It made a difference to keep things cool with 100 degrees outside.
2014 Wildcat 327ck
elind is offline   Reply With Quote
Old 08-31-2015, 10:39 PM   #8
Iwannacamp's Avatar
So I am guessing if I have no other fan I have no "place" for another a/c unit?
2017 Puma 297RLSS
Old 08-31-2015, 10:46 PM   #9
TURBS's Avatar
If you don't have a vent in the area you want to cool then it's probably not a possibility.
Not sure if I follow what your asking 100%
TURBS
2011 32bhok Sabre
