Old 08-28-2016, 12:29 PM   #1
Air conditioner
First weekend with the new 251rks. No news to report, so good news. All systems functioned as advertised.
Question: Day 2 , 13.5 air conditioner picked up a vibration. Not bad just noticeable. Cools fine. Others having a vibration or is this something to deal with at service?
SCtravler is offline   Reply With Quote
Old 08-29-2016, 01:48 PM   #2
Head Rambler
If it wasn't doing it the whole time and showed up all of a sudden, it's something you should check out or have checked out.
It could be a loose or broken blower wheel or condenser fan.
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
Old 08-30-2016, 12:28 PM   #3
Thanks. Made an appt with service before our next week long outing.
Old 09-09-2016, 12:13 PM   #4
Assuming SC means South Carolina, do you find your 13.5k cools your 251 in the summer. I am in GA and it's hot as hell, and I'm a yankee.... So curious your experience with that.
manderson2228 is offline   Reply With Quote
Old 09-09-2016, 04:13 PM   #5
Arctic
We had it in Charleston 2 or 3 weekends ago. Brutally hit and humid. It ran slot but kept it colder than southern transplants could handle ....
Trick is to set to high fan until it cools the trailer than select low fan. That will let the compressor to turn on and off while the fan keeps the cold air circulating.
Where did you buy?
Old 09-09-2016, 04:17 PM   #6
Coolharts's Avatar
Where did you buy?
After this summer I give, going to add a second A/C to mine. It came prewired for one and has 50 AMP service, might as well use it.
2017 Surveyor 33RETS with Residential Refrigerator and Inverter
2015 Palomino Puma 30FQSS --Traded--
2005 Ford Excursion 6.0L 2WD
Nights Camped 2016 27
Coolharts is offline   Reply With Quote
Old 09-09-2016, 07:23 PM   #7
Had thought about getting the 50 amp, may still wish we had, but haven't had a problem. I think if this had been more than 30 ft unit, definitely would have...
air conditioner
