Another Slide Question: Alignment
My 2008 SVT264 Surveyor slide opens fine but as soon as it leaves the closed position the top angles or tips slightly. Then as it approaches full open and comes against the seal it straightens and locks and is straight and properly level. I also notice when it's in the closed position as I look at it from the outside the bottom appears slightly tighter. The guy I bought it from told me this was normal operation and to my knowledge I have no leaks.
I looked under the sofa and can see there is a bracket in the center of the slide that would allow adjustment up or down. Should I adjust this slightly downward or leave well enough alone? Comments...
