Old 08-18-2011, 01:28 PM   #1
Hidaho's Avatar
Batteries
OK, silly question here. Purchased a surveyor and can't figure out how to cut off power to the battery.
Is there a main electrical disconnect somewhere that I can't find. Tried the fuse boxes but the lights, stereo, slide will still function when activated.
Is this going to drain the battery? Is disconnecting the battery the easiest way to preserve its life when its not being used?
Oh, and what is the life on batteries typically?
Hidaho is offline   Reply With Quote
Old 08-18-2011, 01:39 PM   #2
Triguy's Avatar
The parasitic draws in the trailer will draw down a battery in a few weeks to a few months depending on the battery size.
There is most likely not a disconnect in that trailer unless it was installed afterwards by the owner. Marine battery disconnects are the best way to do it. You can find them at any marine store, some auto stores, some camper stores and amazon.
Search this forum for "battery disconnect" for a lot of information to this very popular mod.
Depends on the battery, how its used and how well its maintained. Here's some typical numbers for various batteries...
  • Starting: 3-12 months
  • Marine: 1-6 years
  • Golf cart: 2-7 years
  • AGM deep cycle: 4-7 years
  • Gelled deep cycle: 2-5 years
  • Deep cycle (L-16 type etc): 4-8 years
  • Rolls-Surrette premium deep cycle: 7-15 years
  • Industrial deep cycle (Crown and Rolls 4KS series): 10-20+ years
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 08-18-2011, 08:27 PM   #3
acadianbob's Avatar
I always disconnect my battery while the trailer is stored. If you have electricity available, a Battery Minder is a nice and inexpensive way to make sure your battery is always properly conditioned and charged. Just google Battery Minder. As a user testimonial, I use one on my motorcycle battery; it is a 2003 with the original battery still going strong. I expect to easily get 5 years out of the Trojan deep cycle battery on my trailer.
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
Red Green coffee mugs
Old 08-18-2011, 09:34 PM   #4
Fire Instructor's Avatar
There are inexpensive battery disconnects at Harbor Freight. You can pay up to $75 for a good marine-grade switch type disconnect.
Fire Instructor
2014 RAM 2500 Laramie 4x4 Quad Cab w/Cummins Turbo Diesel, 2009 Rockwood 2607, and 3 'yaks!
300W of Suntech Solar, a Rogue MPT-3024 Controller, and a Xantrex PW2000 Inverter
Fire Instructor is offline   Reply With Quote
Old 08-18-2011, 09:45 PM   #5
camping
tentcamper1's Avatar
I plug ours in when home. battery is always charged and the fridge is cold (just in case)
2007 Chevy 2500HD CC
2010 V-Lite 30WRLTS
Nights Camped 2011 -64
Nights Camped 2012 -50
"I Live in My Own World, But It's OK. They Know Me"
tentcamper1 is offline   Reply With Quote
Old 08-19-2011, 10:55 AM   #6
bikendan's Avatar
i don't know of any TTs that come with a battery disconnect switch, unless a previous owner installed one.
just do a search here or any other RV forum, on the subject and you'll get tons of pics and suggestions.
Old 08-19-2011, 12:07 PM   #7
RV Newbie
buzzards27's Avatar
I got dial type one at West Marine for about $40. I think you can find ones that connect at the batteries for even less at auto parts stores.
2005 FR Lexington 210 6.0L 8500 miles
2007 2500 Silverado Ext. Cab, 6.5' bed 5.7L
2010 Ford Fusion Hybrid
1963 Ford 861 5 speed with loader
1958 Ford 800 Select-O-Speed (parts tractor)
buzzards27 is offline   Reply With Quote
Old 08-21-2011, 04:41 AM   #8
Hidaho's Avatar
Thanks for all the great information and suggestions. I don't feel as lost as I did.
Triguy - Wow. apparently you have done a significant amount of research on the topic previously. Thanks for the information...it is sincerely appreciated.
Old 08-21-2011, 07:55 AM   #9
Triguy's Avatar
You're welcome - research is what I do so it kind of carries over. The numbers for the batteries came from the guys over at Northern AZ wind and sun when I was exploring solar options. Great site.
Scott
2012 Shamrock 233S
Old 08-29-2011, 08:47 AM   #10
Not such a Junior anymore
Borwick's Avatar
I added a Battery Brain Gold (RV model). This has a low voltage cutoff, which means it disconnects your batteries from any draw when the level is below safe levels.
It also has a little switch that is a complete cutoff of the battery to power center. It is mountable right on the battery post, or somewhere along the cable to the first power draw point.
I mounted the cutoff switch inside the trailer so that I can reset it if its tripped, or if I want to completely cutoff power to the trailer for storage.
Dave & Tami
Borwick is offline   Reply With Quote
battery
