Old 07-07-2014, 10:44 PM   #1
Bed Light cable on SV235RKS
The previous owner apparently broke the cable by bringing the slide in while the plug was connected. So, I don't know whether this is the original cable and jack or if he made it work with what he had. Does anyone have picture of the original plug and connector/jack for this light connection?
The one we have now appears to be a microphone jack and plug. I am sure it is rated for the minimal amperage that the two bulbs pull, but I am not sure it is original to the trailer.
madmaxmutt is offline   Reply With Quote
Old 07-09-2014, 08:31 PM   #2
mTn_biKer65's Avatar
Here's the end of the cable on the bed. Unfortunately the bed's in so getting the female connector is a little more difficult but let me know if you need it as well.
ID:	57777   Click image for larger version
Nights camped
2007 Shamrock F19 hybrid - 2010 (22 nights), 2011 (24 nights), 2012 (11 nights)
2013 Surveyor Select 235RKS -
2012 (6 nights), 2013 (32 nights), 2014 (26 nights), 2015 (37 nights), 2016 (14 nights)
mTn_biKer65 is offline   Reply With Quote
Old 07-09-2014, 08:54 PM   #3
Thanks!! I can work with that. The guy had wired in a microphone jack and plug. I will make it right. Thanks again.
Old 08-05-2014, 10:59 PM   #4
Update/Correction:
So, after a little more research . . .
This thing is not only 14 gauge wired 12V rated, but is indeed a "Bunk Light Adapter" capable of supporting two bulbs or a bulb and fan combo.
It turns out the only real problem was/is the scary looking wiring connection (done by the previous owner) in the second photo. Why it was cut so close to the plug is beyond me. I ordered one of the lights and will make a clean splice connection using that cord this time.
ID:	59791   Click image for larger version
Name:	jack - Copy.jpg
Old 05-03-2015, 12:11 PM   #5
UPDATE
I am just getting around to fixing this permanently after the long winter. I was never able to find the stock connectors locally and I was afraid they would just get ripped off again without some improvement to the way it functions.
My solution was to buy a "bed fan/light" similar to this one. http://tweetys.com/images/products/d...58310_silo.jpg
I simply removed the properly rated cord from this fan/light for use with the slide bed light and the existing bunk light adapter that the previous owner installed.
Finished picture:
Name:	Bed Light Cable Installed.jpg
The slide now operates freely whether the stretchy cable is plugged in or not.
Old 06-05-2015, 10:24 AM   #6
Where did you get that fan?
maxjr758 is offline   Reply With Quote
Old 06-13-2015, 10:18 PM   #7
Sorry for the delay, 2 weeks camping in parks. . .
I bought the fan from etrailer. etrailer fan bed light - Bing=
bed, light
