Old 12-29-2013, 06:19 PM   #1
Black/Gray tank drains, which is which?
Just bought a 2007 Surveyor SV 230.There is no labeling describing which drain is which. On my trailer the forward drain, closest to and behind the rear wheel, has a T-handle that moves forward to drain. The rear drain, closest to the back of the trailer has a long T-handle the goes toward the passenger side and disappears through the underbelly covering. Which is which?
azjerry is offline   Reply With Quote
Old 12-30-2013, 09:02 AM   #2
ptt87's Avatar
My guess is that the rear drain is your black water drain, as it is closest to your toilet. If I'm looking at the correct floor plan for your trailer, the toilet is in the rear of your trailer - is that correct? Your forward drain sounds like it is directly under your kitchen sink, so it is likely the gray water drain.
If still in doubt, put a half gallon of RV antifreeze down your kitchen sink, and then open your drains to see which one drains pink.
Pete & Laurel
Peachtree City, GA
2012 Surveyor SP280
2007 Ford F-150, 4.6L V-8
Equal-i-zer
ptt87 is offline   Reply With Quote
Old 12-30-2013, 09:54 PM   #3
Anacortesians
The bigger diameter pipe is tha black tank and the smaller one is the grey tank.
Frank and Eileen
No longer RVers or FR owners
Old 12-30-2013, 10:51 PM   #4
I think my unit has a gray handle and a black handle? Unit in storage, so not 100% sure.
2016 Siverback 33IK
2015 Ford F-250 Lariat 6.7L V8 Diesel 4WD Super Cab
Old 12-30-2013, 11:31 PM   #5
Unfortunately, both pipes are the same size and color.
There's no labeling on pipes, handles or the side of the trailer.
Jerry
2013 F150 Ecoboost
Old 12-30-2013, 11:31 PM   #6
Professional Curmudgeon
Exactly.
2002 Forest River Flagstaff 8528RLS
2014 Coachmen Catalina 253RKS
2016 Keystone Summerland Mini 1750RD
2012 F250 Lariat 6.2L Crew Cab FX4
wrvond is offline   Reply With Quote
Old 12-31-2013, 04:59 AM   #7
Todouble's Avatar
Put a clear adapter on it and take a lucky guess! You will find out instantly which is which. Then label it or mark it somehow
Todouble is offline   Reply With Quote
Old 12-31-2013, 11:50 AM   #8
bikendan's Avatar
you may have two gray tanks, one for the galley and one for the bathroom sink and shower.
the black tank pipe is ALWAYS a bigger diameter pipe than the gray, unless the factory screwed up the installation.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 12-31-2013, 06:15 PM   #9
All I can say is, "DOH!" I don't know how many times I looked at those two drain caps and said "those are the same size!" I finally looked at the pipe before the drain valve for the one I can see (the other is above the underbelly covering. Sure enough, the pipe is a smaller size.
I don't remember seeing this on my previous trailer. But then again, they Y-ed together and the valves were clearly labeled.
Thanks everyone.
Jerry
2013 F150 Ecoboost
Old 12-31-2013, 07:58 PM   #10
Brother Les's Avatar
We can only learn from our mistakes. If we make no mistakes, then we have learned nothing. You were given the correct advice and looked and failed to see that it was correct. Looking a little deeper, you found that it was you that was in error and you learned from your mistake. You then took that a step farther and told us about your 'Ah-ha' moment. This shows great character and honesty. Enjoy your new '07 camper
Blessings
Brother Les
black, drain, tank
