Old 06-12-2016, 10:23 PM   #11
Here's what's happening in a nutshell. I keep black tank valve closed until leaving. Indicator is stuck on 3/4 full since new. I open the valve until nothing flows. I use my tank flush until I can see water through my toilet opening. Dump again. When get home I open the valve with a bucket under the drain and always get a bucket full of solids. It's like the drain is higher than the bottom of the tank. I will try adding some chemicals to see is it helps. I haven't been using any chemicals due to short weekend trips. Lots of campers told me they don't bother with chemicals so I quit using them.
JJ77 is offline   Reply With Quote
Old 06-13-2016, 12:22 PM   #12
I always start with 3-4 gallons of water in the black tank at the beginning of the trip. It is supposed to help loosen up anything that may be stuck in the tank from previous trip.
Maybe you need to modify your diet.
2015 Solaire 201SS
2015 GMC 2500HD Duramax
PSU Turf is offline   Reply With Quote
Old 06-13-2016, 12:24 PM   #13
After draining the black water tank I fill a bucket up with fresh water. Dump that in the tank and open the valve again. I always use some type of treatment for the black water tank.
dnjsellars is offline   Reply With Quote
Old 06-13-2016, 12:48 PM   #14
That's one of the funniest things I've ever seen on these forums! ROFL
dstacy969 is offline   Reply With Quote
Old 06-13-2016, 01:09 PM   #15
I would think with all the beer I drink while camping there would be enough liquids in there to keep things flowing! Diet? what color is it now?
Old 06-13-2016, 01:17 PM   #16
RollingDownTheHighway's Avatar
I recommend not relying on the indicators, just as a guide. The indicators in my 3200BHT have read 3/4 full since we brought it home new from the dealer. When it drains at first, it'll read empty and then one flush read 3/4 full and then full. I leave my valves closed and drain it every other day while staying at the CG. I then drain it and use the black tank flush as well. I run that a few times until the water comes out "clear" and then eventually stops.
Why do you think it's not emptying 100% outside of the indicators?
2013 Prime Time Tracer 3200BHT
2016 Chevy 3500 CC, DRW (aka: bigbootyjudy)
Ribs in the smoker and Whiskey in hand
RollingDownTheHighway is offline   Reply With Quote
Old 06-13-2016, 05:55 PM   #17
crunchman12001's Avatar
Try this black tank treatment, it is the best that I have used. No odor and breaks down the solids.
Happy Campers 18 oz - HAPPY CAMPERS RV | HAPPY CAMPERS RV
2015 F-250 FX4
Old 06-13-2016, 06:27 PM   #18
Flybob's Avatar
X2 on Happy Campers. Used that in the last three TT and no issues.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 06-13-2016, 07:33 PM   #19
Mr. Dan's Avatar
Same here.
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 110 / '18 = 28; booked = 34
Old 06-13-2016, 09:14 PM   #20
Evereddie's Avatar
Cutout. Maybe the cutout from when they cut the hole in your tank is still in the tank. Many have had this happen. Search the forum for this.
There are 10 types of people in the world.
Those that know binary, and those that don't.
2013:31 / 2014:51 / 2015:58 / 2016:37 / 2017:46
2018:16
Total 239
Evereddie is offline   Reply With Quote
black, black tank, tank
