Old 10-13-2014, 07:28 PM   #1
Tooljunke's Avatar
Black tank flush
Hello, I have another newbie question. My 264 rks has a black tank flush connection on the door side , while being hooked up at a full hookup campground last weekend , I tried it out but don't know if I did it right or not. I haven't found any literature on how to use it so I just guessed. After dumping my black tank I turned on the water to the flush connection and opened and closed my waste gate several times fearing overflowing the tank I didn't keep it closed off long. Is this the proper way to use it ? Also does it spray water around in there or just fill it with water ? Thanks
2004 Dodge Ram 1500
2015 Forest River Surveyor 264 rks
Tooljunke is offline   Reply With Quote
Old 10-13-2014, 07:39 PM   #2
WFD
It's similar to a sprinkler head and shoots water around inside...takes a while since the line going into the tank is only 1/2"...so you can leave it run a few minutes then open the valve and repeat a few times...just don't walk away from it when you are doing it as you may get distracted and forget about it, then you have a big poopy mess!
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
Old 10-13-2014, 09:06 PM   #3
Tooljunke's Avatar
Thanks for the help. I really like this forum , everyone has been very helpful. I've learned alot.
2004 Dodge Ram 1500
Old 10-13-2014, 09:19 PM   #4
I have timed it and it seems to take approx. 8 minutes for mine to reach full. So I let it run 4 minutes with the valve closed. Open it till I hear the flow slowing down. I probably over kill it but I do this many times, 7 or 8, depending on how much time I have that morning on our break down to load up and move out.
Buck1032 is offline   Reply With Quote
Old 10-13-2014, 09:25 PM   #5
Ret E-9 Anchor-clanker
donanddona's Avatar
When I'm at a full service campground I monitor the drain hose and the level lights. You should be able to hear the blank tank start to empty. I turn on the flush hose after it has been draining for 15 seconds or so. You should hear a continuing drain of water, nothing major. Then I will monitor the black tank level lights. Not all will extinguish very time so I use a little common sense and shut the water off after 15 minutes or so. You can use a removable clear adaptor between the tank drain connection and your drain hose to monitor water color. Good luck..
:trin k39:
donanddona is offline   Reply With Quote
Old 10-13-2014, 09:38 PM   #6
Tooljunke's Avatar
Thanks everyone. Now if I can just remember where I left my coffee cup.
2004 Dodge Ram 1500
Old 10-14-2014, 09:19 AM   #7
I cannot help with the MIA coffee cup. But I assure you mine is right in front of me.
2017 Keystone Cougar 28RDB
Old 10-14-2014, 07:41 PM   #8
WFD
Hope the coffee cup isn't in the toilet!!!
Old 10-14-2014, 09:50 PM   #9
Nope, about thirty yards from it. Felt safe drinking it at that distance.
black, black tank, black tank flush, tank
