Old 09-14-2013, 10:00 AM   #1
Paulpro4x's Avatar
Brake Adjustment
Has anyone adjusted their trailer brakes?
I read that the brakes should be adjusted after the first few trips. I removed the inspection cover on the back of the backing plate expecting to see a star wheel like on an older cars drum brakes but didn't see anything. Is there a way to adjust them without removing the wheels?
Thanks!
2013 SP220
2010 Nissan Frontier Pro4X
Dave's RV Center, Danbury, CT.
"It's okay for a man to smell like bacon"
Paulpro4x is offline   Reply With Quote
Old 09-14-2013, 10:04 AM   #2
rbneron's Avatar
Etrailer has a very good video illustrating how to do this.
rbneron is offline   Reply With Quote
Old 09-14-2013, 10:38 AM   #3
rattleNsmoke's Avatar
Paul, grab a flashlight and look hard. There has to be some sort of star wheel. It might be real far to one side and tough to locate. Without it, it would be almost impossible to adjust.
Worse case scenario....take off one drum and you'll see clearly what your up against.
rattleNsmoke is offline   Reply With Quote
Old 09-14-2013, 03:33 PM   #4
Paulpro4x's Avatar
I looked in there with a flashlight and didn't see an adjuster. Next week I'll be moving it closer to the garage and then I can pull a wheel off and see exactly what's up.
2013 SP220
Old 09-14-2013, 06:26 PM   #5
raspivey's Avatar
Look through your manuals for the trailer and see what the paperwork for the brakes say. On my new trailer, they claim to be "self adjusting" and never need to be touched manually. My last ones had an adjuster wheel. Without looking, I think Dexter makes my new ones. There still should be an adjuster in there somewhere, you just might not need to mess with it. On another note, I haven't looked to see on this trailer, but the adjuster on the last one was really hard to see..had to almost do it by feel.
Old 09-16-2013, 11:35 AM   #6
tanddc's Avatar
Paul,
You should have self adjusting brakes on the SP220.
Tim
tanddc is offline   Reply With Quote
Old 09-16-2013, 07:04 PM   #7
Paulpro4x's Avatar
Thanks guys.
I'll check the paperwork to be sure, but I believe they are self adjusting.
Paul
2013 SP220
Old 09-18-2013, 07:31 AM   #8
Wanna Be Camper
SaskCampers's Avatar
Even if they are self adjusting they will have the star wheel. There should be 2 plastic plugs on the back of the assembly, take the 2nd one out if you did not see a star wheel under the 1st. Here is a pic of a self adjusting 10 inch brake assy and note the star is still there as that is used by the system to do the adjusting just like the old days of drum brakes on a car. Note the 2 plugs in the second pic.
ID:	39931   Click image for larger version
John & Deb
2011 Flagstaff V-Lite 30WRLS
Days Camped 2016: 3 2017: 0
brakes
