Old 05-14-2016, 01:11 PM   #1
Cant find Battery disconnect 2016 251RKS
Anyone know where the batt disconnect is at? It's on our build sheet, but the dealer cannot find it. They will install a different one of free, but it seemed odd a few of their maint guys could not find it... Thanks!
Living4Christ is offline   Reply With Quote
Old 05-14-2016, 01:24 PM   #2
raspivey's Avatar
They've started putting them outside on the frame as opposed to the push/pull things they've been using. Look for a red key type switch on the frame just behind the bottles.
Old 05-15-2016, 06:06 PM   #3
Thanks a lt for the tip, but it is not there. Anyone out there with a Surveyor that might know where the factory battery disconnect might be?
2016 FR Surveyor 251RKS. Mods (so far): 2nd battery with solar battery tender, cover, Air Maxx vent covers
Old 05-16-2016, 08:28 AM   #4
Battery Disconnect
There's not one on our tt.
(and a call to F/R looking for specific info resulted in wrong info as to interior support framing)
caveat emptor
Retired U.S. Coast Guard Mustang
Presently a librarian @ Duke
2016251RKS is offline   Reply With Quote
Old 05-16-2016, 01:30 PM   #5
our 2014 avenger didn't have one anywhere
ValMelton is offline   Reply With Quote
Old 05-16-2016, 06:17 PM   #6
Mine doesn't have one.
Humteddy2
2014 Silverado Z71 LTZ 1500
2017 Surveyor 285IKDS
Humteddy
2017 Surveyor 285 IKDS
2016 GMC Sierra Denali HD 2500 Duramax
Humteddy2 is offline   Reply With Quote
Old 05-16-2016, 06:30 PM   #7
Oaklevel's Avatar
Not sure what model you have but our son's Surveyor nor our Puma came with one.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Old 05-19-2016, 12:01 PM   #8
talmadge's Avatar
I put one on myself, from our other camper, bought it from Camping World. I mounted mine on the frame side rail under the tanks. working out very well, plus it is hidden from sight and easy to get to.
Tal and Debra
2016 Forest River Surveyor 251RKS
2003 Chevrolet Silverado
2014 Ram 1500 Laramie Crew Cab 4x4
talmadge is offline   Reply With Quote
Old 05-23-2016, 04:55 PM   #9
Battery cut off
I had to have one added to my 2016 251RKS. Definitely a wise move.
Sounnder is offline   Reply With Quote
Old 05-24-2016, 07:50 AM   #10
Just wondering why? What's the benefit of a disconnect?
Old 05-24-2016, 08:32 AM   #11
talmadge's Avatar
It will save the life of a battery, if like we do store a few months, plus keeps from always disconnecting the battery cables. Before I got one, I always left mine hooked up to the battery, about 3 months of none use I would here a beeping noise in the camper, it was the low battery warning beep, I put one on right after that and turn the switch to off when not using, on our other camper, I had the original battery for 6 years before replacing by doing this.
Tal and Debra
Old 05-24-2016, 08:54 AM   #12
our last camper (a 2014 Avenger) did not have one
the led lights for the stereo as well as the microwave would run the battery down when we would store the camper between camping trips, even though we shut everything down, they would all still run off of the battery, so we would have to take the battery cables off to keep from running the battery dead. the disconnect stops that from happening.
Old 05-24-2016, 08:57 AM   #13
our Avenger did not have one, we had to disconnect the cables (remove them) when we weren't using the camper to keep from having a dead battery when we stored it
Old 05-30-2016, 07:09 PM   #14
ALL trailers should (but dont) have a battery disconnect because when you park your trailer and drive away there are small draws on your battery from things like carbon monoxide detector, radio/DVD type devices (even though they are powered off), etc that will eventually drain your battery over the course of a couple weeks...not good.
Since "Battery disconnect" was on my Surveyor's list of equipment I asked the dealer to find a third party switch & install it for free, which they did. Thanks for input from everyone.
battery, battery disconnect
