Old 02-13-2019, 06:01 PM   #1
NewRvrDDC's Avatar
Caution,,Careful Where You Put Your Hands.
Recently while just checking out our new TT Surveyor 247 BHDS I put my hand on the top corner of the kitchen slide and low and behold found some very sharp metal..
Looks like the detail work in the trailer went by the wayside when they got to the slide.
I took the loose ends and bent them down and then put a heavy strip of Gorilla tape over it just as a safety precaution for the next curious person.
Picture attached.
NewRvrDDC is offline   Reply With Quote
Old 02-14-2019, 10:14 AM   #2
clarkbre's Avatar
Thanks for the tip. I'll be checking mine for sure.
2017 Forest River Surveyor 247BHDS...
...Tugged by a 2016 F250 XLT FX4 SuperCrew, Shortbed 6.2L, 4wd, 3.73...
...Joined with a Husky Centerline TS 800-1200lbs WDH
clarkbre is online now   Reply With Quote
Old 02-14-2019, 10:46 AM   #3
WOW !! I've never seen anything that bad.
TheWolfPaq82 is offline   Reply With Quote
Old 02-14-2019, 11:07 AM   #4
Denver To Yuma In 90 Days
Incredible...
Although I have also seen some other amazing work out of the RV factories that was just as mind boggling.
"Just because someone has been "doing it for years with no problems" doesn't mean YOU should!"
2015 Heartland Prowler P292 5'ver, Reese 16K Pro Slider Hitch
2015 Chevy 2500HD 6.0L Gasser w/4.10 rear end
JohnD10 is online now   Reply With Quote
Old 02-14-2019, 11:33 AM   #5
Decon Blue's Avatar
Sadly that was probably done by one of there Top Notch employees.
Retired and loving it. Still looking for that perfect high.
Decon Blue is offline   Reply With Quote
Old 02-14-2019, 12:00 PM   #6
WOW!... that is TERRIBLE workmanship by someone.
That needs to be brought to someone's attention.
Days Camped: '15=22 '16=46 '17=30 '18=51
Old 02-14-2019, 12:43 PM   #7
Out of sight, out of mind... Hopefully you didn't get cut too bad. That could have been a bad deal.
PondSkum is offline   Reply With Quote
Old 02-14-2019, 02:36 PM   #8
Looks like they cut it with a dull steak knife!
Ben
benfox49 is offline   Reply With Quote
Old 02-14-2019, 02:51 PM   #9
Mr Towed's Avatar
Ben
How dare you insult dull steak knives like that!
Travel Trailer: 2004 Flagstaff 25LB
New Tow Vehicle: 2017 F-150 3.5 Ecoboost, supercrew short bed FX4 Lariat
Old Tow Vehicle: 2009 Silverado 2500HD 4x4 Ext. Cab Short Bed
Cats: Rhody and Hazy
Mr Towed is offline   Reply With Quote
Old 02-14-2019, 03:49 PM   #10
Plastic trim?
Picture attached.
Is there room to put plastic angle trim (like you would put on the outside corner of a plaster wall) in this area. These two are self-adhesive and inexpensive:
96-inch
48-inch
Larry
Larry-NC is offline   Reply With Quote
